Rating: 5
Page 1 of 9 1 2 3 4 5 6 7 8 9
Not just another 3.4 swap... #964866 09/25/09 04:06 AM
G
Greg_Canada Offline OP
Hey guys (and girls), i've been wanting to do this for years, and it wont be complete for probably another 6 months, but here we go.
Ooh... a 3.4.
Powerwashed, now tearing it down. (Btw 5 months between these two photos)
More parts removed, (this was about the time i decided to do a rebuild instead of just timing belt/water/oil pump)
Front of motor with everything pulled off,
Top end with valve covers off,
Cams? Little worn...hrmmm....
Pistons
Heads
Stock bottom end girdle, BEEFY
Stock rods
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964867 09/25/09 04:11 AM
G
Now the first toy, the last ever ORS harness / swap kit made,
Bottom end, rebuilt with Arias lightened forged pistons (stock compression ratio), and balanced bottom end.
Rebuilts heads (CNC 3 angle valve job) with Colt Cams Stage 2 262 (sea2skytuning) cams (sorry no good pics yet)
Ported and polished lower intake from some guy off yotatech that never used it,
Plug wires, fuel rails, etc from the same guy,
New engine / tranny mounts
New LCE head, flywheel and pressure plate bolts. Supra twin turbo MAF, rebuilt injectors, misc parts.
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964868 09/25/09 04:11 AM
kewlynx Offline
OOOoooooeeeEEE. Make sure you get a GOOD torque on the crankbolt when you put it back together Greg; it's up there.
Now the swap requires the 3.4 motor mounts; the 3.0 mounts won't work, correct? That's something I need to edit/add in the swap article in the portal that's lacking.
Thanks!
**ubi apis- ibi salus**
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964869 09/25/09 04:19 AM
G
Now the money-maker, in all it's glory, a freshly rebuilt 3.4 with all new moving parts and URD 2.2 pulley.
Wego IV Wideband/data logger from Paradise Racing
MAPECU2, URD Idler Pulley, Walboro 255lph fuel pump
Clutchmasters stage IV clutch,
Downey Headers,
Now, there is lots more, but just, not as "fun"
Full OEM gasket kit, timing belt kit, oil pump, water pump, NEW 98' 4runner engine harness, Supra twin turbo MAF, plug and play EPaO rear o2 simulator (for high flow cats), rebuilt stock injectors (by Paradise Racing cheap and great work), new knock sensor wire (they appear to be 1 time use only) 170 deg thermostat, and probably more.
Still waiting on a URD crankshaft pulley and 7th injector, and i will have everything. Then have to assemble the engine now and throw it in.
Only thing getting in the way of taking the 4runner off the road, is fixing up my winter car, anyone guess what it is?
Hopefully, i can get this post updated soon, thanks for looking!
BTW, i'm looking for 300hp at the wheels, that's my goal... i'd be happy with 275 tho, we'll see.
89 4Runner
Re: Not just another 3.4 swap... [Re: kewlynx] #964870 09/25/09 04:23 AM
G
Thanks!
Actually, it requires the use of 3.0 mounts, from frame to block. The 3.4 mounts push the engine too far back i believe. Rad, engine mounts, etc are from the 3.0. Oh yeah, i got a new rad too, forgot about that (been sitting in the garage for years LOL).
Oh yeah, got a new crankbolt too. Must have.
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964871 09/25/09 04:47 AM
kewlynx Offline
Thanks Greg, so does it look like they'll bolt straight on, or ? If you remember to get a couple pix of them installed, that would be a good add-on. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Not just another 3.4 swap... [Re: kewlynx] #964872 09/25/09 04:49 AM
DRTDEVL Offline
Celica Alltrac
Re: Not just another 3.4 swap... [Re: DRTDEVL] #964873 09/25/09 05:05 AM
gueroblanco Offline
mid 90s celica gt4
'95 runner 3vze/r150f
Re: Not just another 3.4 swap... [Re: gueroblanco] #964874 09/25/09 05:12 AM
G
You guys are too good. Sheesh. It's actually a celica turbo 4wd (canadian model) <img src="/forums/images/graemlins/wink.gif" alt="" /> Hey, it's a toy 4wd right?
I'll make sure to get pics Kewl.
89 4Runner
Re: Not just another 3.4 swap... [Re: Greg_Canada] #964875 09/26/09 06:10 AM
ldivinag Offline
i hate you...
i double hate you...
i double dog dare hate you...
see now you are just pushing it...
well, well... welll... i hope you freeze up there in canada...
lol... jk dude... primo stuff there. i'd ceramic coat them downey headers if i were you though, if they aint already.
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6586 MB (Peak: 0.7854 MB) Data Comp: Off Server Time: 2026-11-02 04:03:03 UTC
