tranny bolts wont say tight
#965258
09/27/09 01:24 AM
so i finally got the new trany in but the bolts that hold it to the engine keep vibrating loose and shake the whole jeep when its running. any thoughts on a quick fix?
88 jeep xj with bad trany waiting on 86 jeep xj with blown engine
Re: tranny bolts wont say tight
[Re: piratepeg]
#965259
09/27/09 01:49 AM
Use locktite on them.. Then check your driveshaft for vibration. Something is shakeing them loose. Most of them stay where theya are put. As a side note are they the correct size bolts? Big Jim
[Re: BigJim]
#965260
09/27/09 03:49 AM
Use locktite on them.. Then check your driveshaft for vibration. Something is shakeing them loose. Most of them stay where theya are put. As a side note are they the correct size bolts? Big Jim they are the ones that came out of the old tranny so i know they fit the holes to the engine. i also have a broken rear engine mount. could that cause them to wiggle out?
[Re: piratepeg]
#965261
09/27/09 04:55 AM
That is part of the problem....
Fix the motor mounts and lock-tight the bolts.
If problems continue, you may have a drive shaft out of balance or u-joint issues.
[Re: piratepeg]
#965262
09/27/09 05:36 PM
Use locktite on them.. Then check your driveshaft for vibration. Something is shakeing them loose. Most of them stay where theya are put. As a side note are they the correct size bolts? Big Jim they are the ones that came out of the old tranny so i know they fit the holes to the engine. i also have a broken rear engine mount. could that cause them to wiggle out? [color:"blue"]Why would you even bother to ask? OF COURSE that could cause them to wiggle out! [/color] Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6069 MB (Peak: 0.6711 MB) Data Comp: Off Server Time: 2026-10-21 16:20:10 UTCValid HTML 5 and Valid CSS
