tranny bolts wont say tight #965258 09/27/09 01:24 AM
piratepeg Offline OP
so i finally got the new trany in but the bolts that hold it to the engine keep vibrating loose and shake the whole jeep when its running. any thoughts on a quick fix?
88 jeep xj with bad trany
waiting on 86 jeep xj with blown engine
Re: tranny bolts wont say tight [Re: piratepeg] #965259 09/27/09 01:49 AM
BigJim Offline
Use locktite on them.. Then check your driveshaft for vibration. Something is shakeing them loose. Most of them stay where theya are put.
As a side note are they the correct size bolts?
Big Jim
Re: tranny bolts wont say tight [Re: BigJim] #965260 09/27/09 03:49 AM
Big Jim
they are the ones that came out of the old tranny so i know they fit the holes to the engine. i also have a broken rear engine mount. could that cause them to wiggle out?
Re: tranny bolts wont say tight [Re: piratepeg] #965261 09/27/09 04:55 AM
4x4Wire Offline
That is part of the problem....
Fix the motor mounts and lock-tight the bolts.
If problems continue, you may have a drive shaft out of balance or u-joint issues.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: tranny bolts wont say tight [Re: piratepeg] #965262 09/27/09 05:36 PM
BigJim Offline
Big Jim
[color:"blue"]Why would you even bother to ask? OF COURSE that could cause them to wiggle out! [/color]
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6069 MB (Peak: 0.6711 MB) Data Comp: Off Server Time: 2026-10-22 12:14:39 UTC
