92 montero intermittent knock(with Pixs now) #965389 09/28/09 02:03 AM
teal9550 Offline OP
I'm considering buying a 92 lwb montero. the current owner says it runs and drives but has a intermittent knock he thinks it comming from the bottom end but it been my experiance that lower end knocks dont come and go. is there a common problem with these motors that might be an easy fix? He only wants 350 for it.
Re: 92 montero intermittent knock [Re: teal9550] #965390 09/28/09 02:11 AM
1
1986powerram50 Offline
I know w/ the 2.4s in the MMs the hydraulic lifters occasionally sound like a knock.
--keRby
Ad Inexplorta
Re: 92 montero intermittent knock [Re: 1986powerram50] #965391 09/28/09 03:54 AM
older v6's had hydraulic lifters that have small oil passages and if they get sticky one might flatten every now and then especially on cold mornings. I think i've known 3 trucks that did this, the bigger lifters came in '98 i think. For the price if the truck is otherwise in good condition buy it and put a motor in it or do a rebuild.
Re: 92 montero intermittent knock [Re: TOASTY] #965392 09/28/09 06:27 AM
4ePikanini Offline
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: 92 montero intermittent knock [Re: 4ePikanini] #965393 10/01/09 04:35 AM
teal9550 Offline OP
ok so i test drove this montero today the knock comes at about 1000rpm then goes away its seems to run fine but it has the oil light on under 1000 rpm. the idle seems to move around as well, is there an IAC valve on these. the guy said is blew a head gasket and they replaced it. there is no water in the oil. i notice that the lower pulley seems to be moving around a little so maybe the knock is comming from that. Any thoughts?
Re: 92 montero intermittent knock [Re: teal9550] #965394 10/01/09 05:07 AM
K_Raider Offline
I wouldn't buy it unless you at least plan on replacing the oil pump. Theres no guarantee the knock will stop either. If the price were right, I would consider it.
EDIT- Just saw the price... I think I would grab it. Its worth that in parts. <img src="/forums/images/graemlins/kewl.gif" alt="" /> The lower pulley moving around like that may be the balancer getting ready to fly. <img src="/forums/images/graemlins/zombie.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: 92 montero intermittent knock now with pictures [Re: teal9550] #965395 10/01/09 05:16 AM
teal9550 Offline OP
Re: 92 montero intermittent knock now with pictures [Re: teal9550] #965396 10/01/09 05:18 AM
K_Raider Offline
O yeah!!!! Snatch that up. Everyone here will help get it going right. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 92 montero intermittent knock now with pictures [Re: K_Raider] #965397 10/01/09 05:24 AM
teal9550 Offline OP
Does the motor have to come out to replace rod and main bearings and the oil pump?
Re: 92 montero intermittent knock now with pictures [Re: teal9550] #965398 10/01/09 05:32 AM
K_Raider Offline
Oil pump.... Im not sure but the rod and mains I myself would think it was easier with it out.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6426 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-06-07 09:11:26 UTC
