front drivers side noise #965586 09/29/09 11:01 PM
supersport35 Offline OP
hello all
I was wondering if anyone can help me or heard this sound before.its a whooshing noise coming from my drivers side front end on my 97 4runner i only hear it when i reach 45mph or more. my runner has 150,000 miles on it. i took off the wheel and checked the brakes and they seem fine. any help would be great thanks.
Re: front drivers side noise [Re: supersport35] #965587 10/04/09 01:16 AM
kewlynx Offline
Might check the grommets where the wire harnesses go thru the firewall to see if one is out of position. That lets a lot of noise in the cab; common on the older Toys.
**ubi apis- ibi salus**
Re: front drivers side noise [Re: kewlynx] #965588 10/06/09 10:12 PM
thanks for your reply,but it sounds more like a rotating noise rather than a wind noise. i'm wondering if it isn't a bad u joint or bearing,but i don't know what they sound like when they go.
Re: front drivers side noise [Re: supersport35] #965589 10/07/09 04:08 AM
kewlynx Offline
Get under there with a flashlight and start looking around; always start with a visual inspection. Check the CV's. After that, get a friend, put the truck in the air on jackstands, and 'drive' it.
Re: front drivers side noise [Re: kewlynx] #965590 10/09/09 01:31 AM
well i got under there again and all the cv boots are in really good shape didn't sound like they made the noise when i spun them, but when i grabbed the drivers side wheel and moved it side to side there was about 1/4 to 3/8 play in the wheel where the other side had none am i safe to say i have a wheel bearing going out or is this normal for the front wheel? thanks all
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-06-22 14:17:58 UTC
