Need clutch and CV shaft info #965940 10/02/09 03:45 AM
shorepig Offline OP
I'm wondering what people have been using for their front axle shafts / CV's. What brand name is considered good quality. As well, I am replacing my clutch. I've been quoted $1300 CAN for a Beck Arnley clutch, or $1400 for a Centerline clutch.
I will be having the clutch installed but may attempt the axle shafts on my own. Is this a difficult job?
92 Mighty Max V6 4x4 SWB
32's, torsion lift, yota lift shackles in the back, rear LSD, 4.22's
safari rack, 3" body lift
85 VW Westfalia Baja beast
1975 HONDA CB500T cafe racer
Sector 9 pintail
Re: Need clutch and CV shaft info [Re: shorepig] #965941 10/02/09 12:41 PM
Sounds like a lot of money. I was time pressed and paid $1300 US for clutch, flywheel and stealer labor on my 95. That was five years ago though.
I have a Centerforce DF on my SWB and like it very much. They say though that the CF II is better for wheeling as it can be slipped better. IIRC, I paid around $350 for it.
My understanding is that Beck/Arnley makes good stuff. Haven't used anything from them yet.
When you do it, make sure to put a new pilot bearing in the flywheel. Also inspect FW for resurfacing possibility.
I would say that if you have the appetite to try the front CVs, you can handle the clutch. The biggest thing is getting it aligned properly. I have an actual input shaft from a scrapped tranny. Can't get any better than that for alignment. You can borrow it if you want.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5897 MB (Peak: 0.6379 MB) Data Comp: Off Server Time: 2026-11-02 12:30:23 UTC
