Page 1 of 3 1 2 3
front end vibration 92 montero rd #965942 10/02/09 06:42 PM
hdmaster5312 Offline OP
Bad vibration starts at about 20 mph and gets worse as I speed up. I have taken the wheels and tires have had them balanced and that did not help the problem.
Re: front end vibration 92 montero rd [Re: hdmaster5312] #965943 10/02/09 09:13 PM
LandRaider Offline
Jack up the front end, and support it with jackstands, and get your prybar out, and start finding the slop in the front end. Control arm bushings, tie rods, ball joints....
Re: front end vibration 92 montero rd [Re: LandRaider] #965944 10/02/09 10:19 PM
Tried that and no luck. Also replaced front wheel bearings and it did not help. I can't find much slop in the front driveshaft so I am wondering if it is a right or left half shaft.
Re: front end vibration 92 montero rd [Re: hdmaster5312] #965945 10/02/09 10:54 PM
LandRaider Offline
You need to fill out your profile so we can see what kinf of vehicle you drive. If you have a Gen2 without locking hubs, this could be a problem. If you have a Gen1 with locking hubs this shouldnt be a problem.
Re: front end vibration 92 montero rd [Re: LandRaider] #965946 10/02/09 11:25 PM
92 rs auto locking hubs.
Re: front end vibration 92 montero rd [Re: hdmaster5312] #965947 10/02/09 11:54 PM
FrankR Offline
Did you check or replace the idler arm bushings?
Frank
Re: front end vibration 92 montero rd [Re: hdmaster5312] #965948 10/03/09 12:50 AM
KrzyDav Offline
A bad belt in the tire would give you the bad shimmy but may still balance out OK.
dave h.
Re: front end vibration 92 montero rd [Re: KrzyDav] #965949 10/03/09 12:58 AM
Ujoints in the rear driveshaft? Tire with flat spot?
Re: front end vibration 92 montero rd [Re: hdmaster5312] #965950 10/03/09 02:06 AM
LRJ4x4 Offline
Make and size of tires ?
Re: front end vibration 92 montero rd [Re: hdmaster5312] #965951 10/04/09 02:52 AM
Did you swam some in from a Gen I? Gen II is fixed hub with CAD...
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6389 MB (Peak: 0.7456 MB) Data Comp: Off Server Time: 2026-06-09 21:59:55 UTC
