4Runner won't stay running #966329 10/04/09 09:10 PM
calisurferdude Offline OP
1991 4Runner 3.0, 5sp, 4x4
It won't stay running unless I'm giving it gas. The battery/charge light is on. I have a brand new battery and both it and the alternator have been tested and are good. I've checked all fuses and fusible links, but nothing. I've recently put a new head gasket on it. New plugs, wires, cap, rotor. 40psi on the fuel pressure. The injectors and cold-start injector is getting fuel. Timing is good...I had recently discovered that the crank was off by about 2 degrees and the distributor was off about 2 teeth, which is why it now stays running as long as the accelerator was being pushed.
1987 Toyota 4x4 w/94 bed, 5spd. Rancho RS5000 shocks Firestone 31's, AISIN hubs, Kenwood deck
1991 Toyota 4Runner 3.0/V6, 5spd. on 31's
Re: 4Runner won't stay running [Re: calisurferdude] #966330 10/05/09 05:10 PM
Adam F Offline
Vacuum leak? Could be a cracked intake hose. Or rotten/cracked vacuum lines.
You checked your timing with a light? Jumped the diag. connecter under the hood? Fixed the distributor issue?
What is the voltage with the truck running? NOT what the truck's gauges say, but what does a MULTIMETER say?
97 4R, stock, daily driver
Re: 4Runner won't stay running [Re: Adam F] #966331 10/06/09 01:08 AM
kewlynx Offline
Also recheck the TPS to make sure it's set up correctly; root of all evil. Sounds like you're trying to chase down 2 problems, not just one.
**ubi apis- ibi salus**
Re: 4Runner won't stay running [Re: calisurferdude] #966332 10/08/09 04:21 AM
dennis140 Offline
check your air box
Re: 4Runner won't stay running [Re: dennis140] #966333 10/09/09 04:18 AM
What would be the cause of the battery light being on though?
Re: 4Runner won't stay running [Re: calisurferdude] #966334 10/09/09 05:22 AM
kewlynx Offline
Check your brake fluid level for starters on that one, just to rule it out, esp if you've checked other basic stuff.
Re: 4Runner won't stay running [Re: calisurferdude] #966335 10/09/09 05:54 AM
Adam F Offline
Could mean your alternator is failing. Thats what happened when mine went out, even though the dash gauge read normal.
Did you ever put a multimeter to the battery while running? How about a load test while running?
Re: 4Runner won't stay running [Re: Adam F] #966336 10/09/09 05:58 AM
Alternator is good. I had it tested.
Re: 4Runner won't stay running [Re: calisurferdude] #966337 10/10/09 01:14 AM
Coyotekid Offline
Well, forget that.
Start the truck, have someone sittin' in the cab keepin' it runnin, and put a volt-meter across the battery, and see what kinda voltage it's puttin out.
-Dano-
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4Runner won't stay running [Re: Coyotekid] #966338 10/10/09 02:57 AM
It's a brand new battery. I brought it in to Pep Boys where it was purchased and they tested it for me and it tested as brand new.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6392 MB (Peak: 0.7620 MB) Data Comp: Off Server Time: 2026-10-21 17:08:46 UTC
