Off Road vs On Road gas MPG #966360 10/04/09 10:07 PM
LRJ4x4 Offline OP
My Gen I 2.6 was a horrible gas guzzler off road.
On Road 17 MPG ( not loaded )
Off Road 8-10 MPG ( loaded for three day trip )
That's a 42% increase in fuel consumption. I had to carry at least 10 Gallons of extra gas on the Mojave Road. You could only stuff about 14 gallons in the SWB Gen I main tank.
My Gen II.5 holds 24 gallons. I have not taken the it on a long haul off road trip. I'm wondering what others have experienced in off road fuel consumption with the 3.5L. I'm hoping it's better the the 2.6 <img src="/forums/images/graemlins/zombie.gif" alt="" />
<img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Off Road vs On Road gas MPG [Re: LRJ4x4] #966361 10/04/09 10:27 PM
4runnerpilot Offline
My 92 with the 3.0 gets about 19-21 in my normal daily driving around and about 15 if I'm in 4wd and using it. The 24 gallons is expensive to fill, but does help with range.
88 Trooper, 2.6 5spd
89 Trooper RS
92 Montero
Re: Off Road vs On Road gas MPG [Re: 4runnerpilot] #966362 10/04/09 11:54 PM
I get 17 max onroad and i get maybe 20+ offroad, what are you crazies doing offroad to get such bad milage? My trick is staying in low range and i might do 15mph once in a while. Now if i was aired down and driving on a dirt road in 4hi i'd probably get 8mpg or less.
Re: Off Road vs On Road gas MPG [Re: TOASTY] #966363 10/05/09 12:31 AM
PHIL_ Offline
Les, I don't have a 3.5, but I will say that my mileage doesn't change that much (in some situations its better), but it really depends on what kind of trail I'm running. I've often thought that an hour meter would be a good little gauge to have, since wheeling is often spent at idle, looking over an obstacle, lining up to pull someone out, etc...
Re: Off Road vs On Road gas MPG [Re: TOASTY] #966364 10/05/09 01:31 AM
LRJ4x4 Offline OP
That's basically it. I'm in 4H going down dirt roads that have spots that require 4x4, Typical desert exploration stuff. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Off Road vs On Road gas MPG [Re: LRJ4x4] #966365 10/05/09 01:48 AM
StockRaider Offline
would leaving it in AWD vs switching to 4WHi gain better mileage? Since the SR has on the fly 4wd it seems like less of a hassle to switch between the two.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Off Road vs On Road gas MPG [Re: StockRaider] #966366 10/05/09 02:53 AM
powerRam50 Offline
i have always done better wheeling than driving.going to browns camp from portland and back i use about 1/4 a tank.i can wheel from 9am to 5pm and use less than that.
Re: Off Road vs On Road gas MPG [Re: PHIL_] #966367 10/05/09 04:44 AM
Red1979 Offline
I get a little worse off road but usually 16 to 18 on and off road. got 18.2 once but not been able to top that yet. i have done almost everything I can think of next to a carb conversion
1987 Dodge Ram 50
2.6 5 speed
2 inch body lift 31x11.50 Swamper LTBs
4.62 gears lsd rear and welded front with lockouts
Weber carb waiting to be installed
Re: Off Road vs On Road gas MPG [Re: StockRaider] #966368 10/05/09 05:10 AM
You might see a little improvement in AWD since there would be no bind/drag while turning but it probably wouldn't be noticable. You guys should really try 4Lo, you can shift through all gears while in 4Lo. It's really easy on the truck it won't have to try so hard especially for you 4cyl guys.
Les, since i've ridden with you i know why your gas milage is so low <img src="/forums/images/graemlins/lol.gif" alt="" /> but it was fun zooming up and down those hills.
Re: Off Road vs On Road gas MPG [Re: TOASTY] #966369 10/05/09 06:04 AM
4xmonty Offline
Les
Youed be surprised to know that you can get 28 gals in your tank by topping off I've done it.Makes for long range <img src="/forums/images/graemlins/kewl.gif" alt="" />
PM me your contact info if you would
Russ
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6443 MB (Peak: 0.7682 MB) Data Comp: Off Server Time: 2026-06-07 07:29:30 UTC
