transfercase rear flange? #966414 10/05/09 02:45 AM
W
wytee Offline OP
Is it possible for the nut that holds the rear transfer case flange on to completely come off when driving down the road?
"IM THERE BUDDY"
Re: transfercase rear flange? [Re: wytee] #966415 10/05/09 02:54 AM
4Crawler Offline
I suppose it could, but the nut is typically staked in place and that deformed lip on the nut makes it hard to remove. Would need the nut to turn outwards until it hit the drive shaft flange, then have the flange slip backwards and then the nut to turn farther and so on until it turned all the way out. The nut should still be trapped between the two flanges.
Re: transfercase rear flange? [Re: 4Crawler] #966416 10/05/09 03:29 AM
W
wytee Offline OP
have you ever heard of the transfer case breaking at the threads for that nut?
"IM THERE BUDDY"
Re: transfercase rear flange? [Re: wytee] #966417 10/05/09 09:27 PM
W
whitetoy Offline
Yes, its very possible. It happened to me about 7 years ago, going up highway 50. Pretty ugly. The 'staking' came unstaked, and it slowly backed out.
Luckily, the damage was minimal, just needed to replace the TC output shaft, TC speedometer gear and the drive shaft. Had to be towed home though (AAA 100-mile tow is a wonderful thing).
Rick
1984 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6004 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-06 01:33:03 UTC
