Rattling from transfer case? #966438 10/05/09 04:12 PM
5
5jackz Offline OP
Went hunting and during trip the car started to make a weird rattling like a loose chain or spun bearing along with the smell of burning gear oil. Engine oil and tranny fluids are good. Managed to drive home over 300 miles with no probs other than the smell and rattling. I have not had a chance to look at her yet.Any ideas? Is the Transfer case chain driven - slipped chain? Thanx.
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: Rattling from transfer case? [Re: 5jackz] #966439 10/06/09 01:23 PM
homerdog Offline
Yes, it is chain driven. Other than that I know nothing about them.
2001 Sportage, TJ 106's, Everet spacers and bumpstops, Bilstein shocks on the rear, cone filter, Crager wheels, 235-75-15 Goodyear tires. Custom front winch bumper by Dave Scott. Currently DOA, but it is a work in progress.
2011 Kia Forte EX
Re: Rattling from transfer case? [Re: homerdog] #966440 10/08/09 05:02 AM
5
5jackz Offline OP
Well got the new transfer case in with a mechanic buddy's help.He thinks my transfer case went due to my tires. I'm running 31x 10.50's on 15 x 8 rims. Hopefully he's wrong as I don't want to go through this expensive routine again. Any thoughts/ ideas?
Re: Rattling from transfer case? [Re: 5jackz] #966441 10/08/09 08:47 AM
bombardj1 Offline
did you drive it in 4wd home? if you drove on dry pavement, you will most likely damage the T/C
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Rattling from transfer case? [Re: bombardj1] #966442 10/09/09 03:20 AM
5
5jackz Offline OP
Nope. Only drove it in 2WD home.
Re: Rattling from transfer case? [Re: 5jackz] #966443 10/16/09 10:31 PM
Hydra747 Offline
Please ask ur Mechanic friend how he thinks the transfer case went out due to having ur tire size???? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Rattling from transfer case? [Re: Hydra747] #966444 10/17/09 06:53 AM
DamKia Offline
Kia Moderator
...or ask me.
I've done it too. Excess wheelspin with the front end coming down hard can shock-load the front diff and tcase, causing the demise of both.
The tcase chain tends to stretch and jump the cogs, giving a ratcheting sound that can also be deceptively similar to the front diff side/spider gears shearing teeth.
Re: Rattling from transfer case? [Re: DamKia] #966445 10/17/09 10:05 PM
Hydra747 Offline
I see.....
So if we get smaller tires on then we'll be fine? <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rattling from transfer case? [Re: Hydra747] #966446 10/18/09 01:15 AM
Everet Offline
I really don't understand how tire size would be an issue <img src="/forums/images/graemlins/confused.gif" alt="" />
I'd need to hear the logic behind it.
(Maybe the larger tires let you run your rig in more challenging places than with stock tires <img src="/forums/images/graemlins/smile.gif" alt="" /> )
I can see how shock via bouncing around and having the tires grab after being airborne or something, might cause it to have issues over time.
If you bought your Sporty new, then you would know the history of any t-case abuse. Otherwise, the previous owner may have driven it on dry pavement some in 4 high and started some damage that you finished.
By the way, is your transfer case behind a 5 speed or automatic? What were you able to pick up a replacement for ($$$)?
Keep us posted on your findings.
Everet
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rattling from transfer case? [Re: Everet] #966447 10/18/09 03:18 AM
fokion Offline
the logik behinde XXXL tyres is simply more stres to the whole thrasnfer system due to weight friction e.t.c.
a stress that isnt desined for
like something the Dana30 that haw problems with tyres larger that 32-33 inch
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6373 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-06-09 10:05:13 UTC
