removing driveshaft in 92 montero rs #966494 10/05/09 11:23 PM
hdmaster5312 Offline OP
Do you have to drain transfer case when you remove driveshaft. And if so how hard is it to fill back up?
Re: removing driveshaft in 92 montero rs [Re: hdmaster5312] #966495 10/05/09 11:56 PM
Back shaft might leak a little. You can jack up to help. Front will leak more. Not sure if jacking up will help totally.
Before doing anything, make sure you can get the fill plug loose. Bad deal to drain first and find out it's stuck.
Filling isn't hard. The trick is to get a piece of hose to fit the end of the 1qt gear oil bottle. It makes it infinitely easier to squeeze and fill.
Re: removing driveshaft in 92 montero rs [Re: MontyMcV] #966496 10/06/09 12:14 AM
0778drz110 Offline
pull the driveshaft out the fluid will come out with it-problem solved.
Re: removing driveshaft in 92 montero rs [Re: 0778drz110] #966497 10/06/09 02:23 AM
point it downhill to pull the dshaft and very little will leak out. buy a jackrabbit pump (hand cranked pinch tube type pump) or a little drill driven pump and a single washer water hose to fit on the hole fittings. Use either to pump the lube into the tcase/diff/m/t. No more hoses blowing off the slippery bottle, no more lube puddles. No more ruined tshirts with castor oil smelling lube juice on them. One of my best "made tools"...
Re: removing driveshaft in 92 montero rs [Re: fasteddy] #966498 10/06/09 04:02 AM
8
89IsMine Offline
I bought one of those push-pumps from the auto parts store -- the one that looks kind of like what you have in a lotion bottle or liquid soap bottle. Worked well for me <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: removing driveshaft in 92 montero rs [Re: 89IsMine] #966499 10/06/09 05:45 PM
I tried one of those, and it came apart under pumping forces with the viscous lube.
Re: removing driveshaft in 92 montero rs [Re: hdmaster5312] #966500 10/07/09 12:51 AM
KrzyDav Offline
I don't drain the case, just put a 2" rubber plumbing cap on , tighten the clamp and take it to deliver the driveshaft to the balance shop in 4wd.
dave h.
Re: removing driveshaft in 92 montero rs [Re: KrzyDav] #966501 10/07/09 05:25 AM
Grasscat Offline
Yeah, but Dave you're Krzy. <img src="/forums/images/graemlins/smile.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: removing driveshaft in 92 montero rs [Re: 89IsMine] #966502 10/07/09 11:17 AM
Mad_Scientist Offline
Eric W.
They work great for me too. Eddy must have Popeye style forearms <img src="/forums/images/graemlins/mrt.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: removing driveshaft in 92 montero rs [Re: Grasscat] #966503 10/08/09 03:10 AM
KrzyDav Offline
That's Right <img src="/forums/images/graemlins/lol.gif" alt="" />
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6376 MB (Peak: 0.7454 MB) Data Comp: Off Server Time: 2026-05-29 18:59:37 UTC
