Page 2 of 5 1 2 3 4 5
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966695 10/07/09 04:34 PM
Kevin C Offline
The converter on the V6 has a slighty higher torque multiplication and slips less with tall tires. 1.96 torque ratio for the 4 cyl Vs 2.06 for the V6 unit. That gets you an extra 11 or so ft lbs of tq at the back of the converter.
The V6 unit also has higher line pressure so it will shift a bit more firmly and hold more torque.
Kevin
Re: which gen1 A\T has the lockup converter? [Re: Kevin C] #966696 10/07/09 06:00 PM
W
WagonMaster Offline
How does one determine the torque ratio for a given trans/converter (assuming stock)?
I've done some googling, but all I find is a million threads about crawl ratio...
Thanks
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: which gen1 A\T has the lockup converter? [Re: WagonMaster] #966697 10/07/09 07:31 PM
Kevin C Offline
I got the torque ratio from the service manual.
Kevin
Re: which gen1 A\T has the lockup converter? [Re: Kevin C] #966698 10/07/09 07:36 PM
mecha_sky Offline
Who reads that? hahahaha
WANTED: 1989-1991 Isuzu Trooper or Mitsubishi Montero, V6, Manual 5-speed, 4 door, Stock, Good looking in and out, runner/driver good. PM w/ info please.
Re: which gen1 A\T has the lockup converter? [Re: mecha_sky] #966699 11/13/09 06:42 AM
zarktheshark Offline OP
Does anyone have confirmation that the P code trans is not the lockup? I pulled a trans from a 90 montero and it has a P code. I have a pic of the torque converter if that helps.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966700 11/14/09 04:10 PM
anyone know for sure? the fsm says that all 90's had the lock up. If i have to return it, I have to do so within the next week in order to get my money back.
'15 Subaru XV
'03 BMW i325
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966701 11/14/09 05:08 PM
haztoys Offline
Mr Zark
We dont know .. for sure .... You cant get all info on a forum .. Lots of forum info is off at times ... Not being a jurk just how the web forums are ... Hit your reman trans shops around you .. Find the pro's who fix auto trans and ask them ... Call one of the big auto trans parts sellers would know ... I can call my people on monday if it would help .. I'm a pro mechanic to pay the bills .. But not a auto trans man one of the few thing I have not really messed with .. Try that it may help...
Have a good day
David
Hazardous Toys inc
Re: which gen1 A\T has the lockup converter? [Re: haztoys] #966702 11/14/09 06:11 PM
justice Offline
Zark, I swapped in a lockup unit out of a Junk yard 91 into my 89 SWB. From what Ive found the data plate under the hood list the non-lockup as a KM-148. The Monteros with the lock-up unit use the Aisin Warner designation of AW-XX sorry I cant remember the last two digits...Also I believe there's a red colored data plate of sorts on the drivers side that has some numbers on it. If i remember right the code A44DL is the lock up unit with the last digit of L the thing your looking for in the lockup version. HTH..
Re: which gen1 A\T has the lockup converter? [Re: zarktheshark] #966703 11/14/09 06:14 PM
Kevin C Offline
Take your photo of the front of the converter and the input shaft and post it. I can tell by looking. I used to have the TSB for reading the codes off the case, not sure where I put it.
Either way the front of the converter is differant enough to tell. There is a raised ring in the front of the case where the clutch is located.
Kevin
Re: which gen1 A\T has the lockup converter? [Re: Kevin C] #966704 11/15/09 02:53 AM
aw372L, a44dl, R code on the tranny side tag.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6428 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-07-09 21:39:59 UTC
