Head gasket worth fixing? #966907 10/08/09 04:56 PM
dailyDriver Offline OP
Yesterday I noticed a good amount of milkshake on the bottom of my oil cap and a little more on the dipstick. Pretty sure headgasket is blown. I have about ~200K mile on an otherwise semi-healthy '94 4cyl 22re, anybody think it's NOT worth fixing? A couple mechanics already told me its not worth the fix this late in the game. This time I don't have the time to do it myself, so I'm stuck between ~$1000 for the hg job or potentially a little more than twice that for an engine swap with a rebuild. Anybody got any advice? Thanks. <img src="/forums/images/graemlins/zombie.gif" alt="" />
DailyDriver: '94 Xcab 4x4, 22RE, 139K miles, STOCK
Re: Head gasket worth fixing? [Re: dailyDriver] #966908 10/08/09 06:21 PM
DRTDEVL Offline
Has the timing chain ever been changed? If not, you may have a cracked timing cover leaking fluid from the back side of the water pump.
You see, when the chain gets older, the plastic guides break. You will usually hear a rattle at start up and at certain RPMs (like 1800-2000). This is the chain slapping around inside the timing cover, wearing a pair of grooves into the aluminum housing. When the grooves become deep enough, the cover cracks on the back side of the water pump and the coolant leaks into the crank case.
Re: Head gasket worth fixing? [Re: dailyDriver] #966909 10/09/09 08:55 AM
Davepet Offline
Hmm,
How well does it run? (power up hills?, fuel economy?)
Is this your only daily driver or a play toy?
What did the compression test tell you? (You *DID* do a compression test, right?)
How tight is your money right now?
How long do you want the truck to keep running?
200K miles, $1k to change the gasket (sounds high) vs $2k for a rebuilt engine?
I'd lean towards the rebuilt engine. A gasket swap makes sense if you can do it yourself for a hundred or two, but at $1K you are halfway to buying another 200k miles, you won't be likely to get another 100k out of that engine with just a new gasket. (I'm not saying it can't happen, but the odds are against you).
Fuel economy & power will also not be so good with the older engine.
Dave
Re: Head gasket worth fixing? [Re: Davepet] #966910 10/10/09 12:51 AM
Thanks for the advice. I did the timing chain myself 3 40k miles ago, so hopefully thats not the problem. Weird thing, after letting the truck sit for a couple of days, rechecked the dipstick and no more milk on it. Also, no more white condensation under oil cap? Weird. I haven't done a compression check yet, guess that's next. Also I found rebuilt 22re's installed for $1300 in LA anybody know of this place?
Re: Head gasket worth fixing? [Re: dailyDriver] #966911 10/10/09 03:45 AM
Ralph Offline
If I had it to do again I'd get a rebuilt engine from http://www.engnbldr.com .
Tell them how you want to drive and they will match you with an engine. Don't worry about California smog, my engine passes easily.
You will never be sorry.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Head gasket worth fixing? [Re: Ralph] #966912 10/10/09 04:40 AM
Davepet Offline
Last I heard, Ted doesn't sell rebuilt engines. He'll sell you the parts you need to rebuild one, but not a complete unit.
Dave
Re: Head gasket worth fixing? [Re: Davepet] #966913 10/10/09 09:09 AM
Ralph Offline
When I purchased my RV Head from him I'm pretty sure he was prepairing a long block.
I could be wrong.
Ralph
Home Made Cat Backs
Re: Head gasket worth fixing? [Re: dailyDriver] #966914 10/10/09 07:37 PM
DRTDEVL Offline
Have you lost any coolant? Look in the radiator to see if it's up to the proper level.
During periods where the truck cannot reach full operating temperature for a long period of time (like lots of 1-2 mile trips for weeks on end), condensation *can* build in an engine to the point of the white condensation.
I had an Olds 350 rocket like that. If I only "warmed it up" in the driveway without driving it or only took it to the store and back, after about a month, I would see the froth on the oil cap. I thought the worst the first time, but after a good run on the highway, I rechecked it and all was well.
Re: Head gasket worth fixing? [Re: DRTDEVL] #966915 10/12/09 02:46 PM
engnbldr Offline
>>>*DRTDEVL is right on this one, I wish I had a dime for every head that came in because of a "coolant" leak that just turned out to be a combination of short drives in damp weather.
There is always moisture drawn into the engine when it is shut off, because air contains water, and both the exhaust and intake systems remain partially open when the engine is stopped.
It is common for the engine to reintroduce moisture through the EGR system also as the engine is started. Small amounts are harmless, and it is always there.
If the evidence goes away after the engine is fully warmed up, then not to worry because if it really is a leak, she will let you know.
The old rule of if it ain't broke, don't fix it applies....*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6305 MB (Peak: 0.7354 MB) Data Comp: Off Server Time: 2026-11-18 03:08:14 UTC
