Looking for a mechanic #966916 10/08/09 05:13 PM
samron333 Offline OP
Hi there, I don't have the knowledge to figure out what it is going to take to fix my truck, looking to find out if anyone knows a reliable mechanic in the Sac area or someone that knows these trucks, 84 with a 22r. I don't want to take it to just anywhere and drop it off and of course any mechanic you talk to you will tell you their the best.
84 Longbed, 31 Mud Terrain SXT, rest is stock
CBR 1000, for when i need to hit sixty in less than thirty seconds
Re: Looking for a mechanic [Re: samron333] #966917 10/08/09 06:01 PM
W
whitetoy Offline
What is wrong with your truck?
If you are having differential or transfer case issues, then I recommend "River City Differentials" in Rancho Cordova ( 852-7109 ). Sean is the best gear-guy in town. Even the local Toyota dealership sends him work. Not too far from you. He's a great guy. Tell him Rick sent ya.
For other repairs, I recommend "Japanese Imports" downtown (17th and J) 442-9007. I do most repairs myself, but anything that I can't do, I use them. I also take my wife's Lexus there.
Both are very honest and reasonably priced .
Rick
1984 4Runner
Re: Looking for a mechanic [Re: whitetoy] #966918 10/08/09 07:30 PM
Thanks for the info, it won't pass smog, the system won't even let it start the test. It runs really rough and I have tried several times to get the timing and A/F ration to be correct. As far as I know, I have done everything correctly. I am going to try again this weekend but as it is getting colder and I hate riding my motorcycle in the rain, I am getting desperate.
Re: Looking for a mechanic [Re: samron333] #966919 10/08/09 09:10 PM
W
whitetoy Offline
Basic tuneup (plugs, wires, PCV, valve adjust, etc)
Look for a vacuum leak.
Do a compression test.
Rick
1984 4Runner
Re: Looking for a mechanic [Re: whitetoy] #966920 10/08/09 09:35 PM
The engine is new and so are the plugs and wires, I don't have the tools for a compression test and not quite sure how to check for vacuum leaks. I have manual that I have not looked at for a while, guess it is time to pull that back out.
Re: Looking for a mechanic [Re: samron333] #966921 10/09/09 01:03 AM
W
whitetoy Offline
Well, if the engine is new, then the compression in all cylinders should be good, unless you got a bad motor. Maybe the vacuum lines are not hooked up right, easy to make a mistake there.
Compare what you have, to what the manual says. Check for any cracked or split hoses. Don't leave any hoses out. It runs best with everything connected, and should pass smog also.
Rick
1984 4Runner
Re: Looking for a mechanic [Re: whitetoy] #966922 10/09/09 02:48 AM
I am going to take a look at it this weekend and give it one more shot. I am Ok with my mechanic skills and have basic tools which usually causes somethings to take longer which is why I am looking at other resources. I am feeling short on time, lets here for procrastination!
Re: Looking for a mechanic [Re: samron333] #966923 10/09/09 03:45 AM
OOP'S Offline
Great mechanic, great place to buy parts.
http://www.davezoffroadperformance.com/
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Looking for a mechanic [Re: samron333] #966924 10/10/09 03:54 AM
Ralph Offline
That's my personal mechanic, Jeff.
He has a mobile repair service.
He put my engine together from 2 boxes of parts.
He had his own shop for 25 years and was zoned out of business so he puchased a large van.
He does all of my work, my kids work and a lot of my friends.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: Looking for a mechanic [Re: Ralph] #966925 10/12/09 05:18 PM
Thanks for the references, I am going to check both out and see what I can get done.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6330 MB (Peak: 0.7367 MB) Data Comp: Off Server Time: 2026-06-07 11:15:19 UTC
