Is this ECM fixable? #966998 10/08/09 11:04 PM
mitsumonki Offline OP
ok found the problem the old common leaky capacitors
but i not sure if it is a an easy fix it leaked to the left here and has discolored several components. I can just replace the capacitors but I'm worried that more needs to be replace which means ill be mailing it out for repairs [Linked Image] [Linked Image]
Re: Is this ECM fixable? [Re: mitsumonki] #966999 10/09/09 12:32 AM
With the right tools, replacement parts, and skills it's easily fixable.
Seriously though if you haven't done a lot of soldering, I'd practice on something else first before tackling this job yourself. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Is this ECM fixable? [Re: off-roader] #967000 10/09/09 03:34 AM
V
vr4 Offline
what year/model? i might have one.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Is this ECM fixable? [Re: vr4] #967001 10/09/09 04:42 AM
93 v6 pickup part# md162826
Yea I understand fixing the capacitors is possible but the second picture is pointing to more damage then just needing soldering those two black squares looked messed up along with the board they are on
Re: Is this ECM fixable? [Re: mitsumonki] #967002 10/09/09 05:01 AM
V
vr4 Offline
i dont think i have that one but ill check the stack.
91 MR2 turbo
Re: Is this ECM fixable? [Re: mitsumonki] #967003 10/09/09 05:28 AM
LRJ4x4 Offline
I remember there is a shop that fixes ECU's. Can't remember the name but it's in the search somewhere.
Re: Is this ECM fixable? [Re: LRJ4x4] #967004 10/09/09 05:32 AM
1
1986powerram50 Offline
The MM is a different PN, tho I'd like to get ahold of an monte ECU to see if it could work in a MM.
And finding a pickup ECU is damned hard. Least one you wanna buy haha
--keRby
Ad Inexplorta
Re: Is this ECM fixable? [Re: 1986powerram50] #967005 10/09/09 03:21 PM
V
vr4 Offline
im sure it is. ive used a diamante ECU in a 3000gt.
most likely its a different PN due to the case.
91 MR2 turbo
Re: Is this ECM fixable? [Re: 1986powerram50] #967006 10/09/09 03:25 PM
87Montero Offline
I have an ASE Rebuilt ECU for a 1991 Mitsu Montero.. It's Federal/Cali Compatible for 1990-1991 Monteros if you want to cross reference it with what you've got.
I'm looking to get $80 shipped.
Re: Is this ECM fixable? [Re: 87Montero] #967007 10/09/09 06:55 PM
1
Whats p/n on it? I know all 90-94 3.0 MM federals run the p/n he mentioned above. I'd hate to buy one and blow it up. That would be a kick in the crotch
--keRby
Ad Inexplorta
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6424 MB (Peak: 0.7660 MB) Data Comp: Off Server Time: 2026-11-15 19:38:36 UTC
