1st gen pickup Driveshaft rattle #967313 10/11/09 02:35 PM
Mikewarme Offline OP
I have a 83 turbo diesel pickup. It rattles from the driveshaft when you drive with a light load on the engine. Real loud when almost lugging it. Its not the rear end (I pulled the 3rd member and checked it) and its not the U-joints. However the T-case has slop in it. If I lift the rear end up and turn driveshaft has about 1/4-3/8 play coming from T-case. Do the chains wear in these things? Whats weird is I switched t-cases when I rebuilt the trans and it has the same symptom.
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967314 10/11/09 04:16 PM
lordtrunks Offline
The 5 speed chains do stretch and will make noise.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967315 10/12/09 06:40 PM
ES_97Sport Offline
Also check the yoke. When they start getting loose, they'll cause all kinds of strange noises.
Re: 1st gen pickup Driveshaft rattle [Re: ES_97Sport] #967316 10/14/09 04:26 PM
I have removed the driveshaft 2 months ago and checked carefully. All is tight. You can see the slop coming from the T-case. But the nly the front driveshaft is driven by the chain, right?
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967317 10/14/09 04:32 PM
Is the steel bushing or the front yoke (most likely) on the tcase rear output worn, letting the front yoke wobble? May need a new front yoke for the rear dshaft.
Re: 1st gen pickup Driveshaft rattle [Re: fasteddy] #967318 10/14/09 08:21 PM
No there isnt any side ways slop. The spline feels tight, it is clearly in the T-case. Maybe a worn counter gear?
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967319 10/15/09 11:43 PM
Is there anybody here with Transfercase expierience??
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967320 10/17/09 01:35 AM
Is this issue in 2WD or 4WD?
The output bushing on the rear shaft is the first part to wear out.
Re: 1st gen pickup Driveshaft rattle [Re: OldColt] #967321 10/17/09 04:14 AM
in 2wd. Its not the bushing cause the shaft is tight side to side. It's gear backlash or the chain maybe
Re: 1st gen pickup Driveshaft rattle [Re: Mikewarme] #967322 10/17/09 08:06 AM
In 2WD the transfer case is a straight through drive. The chain is stationary, there are no gears under load.
The chain only spins with the front driveshaft when in 4WD.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6384 MB (Peak: 0.7444 MB) Data Comp: Off Server Time: 2026-11-02 11:52:39 UTC
