Swap an Auto for a 5spd #967380 10/12/09 12:44 AM
dolomiti Offline OP
Well, I tried a search several times with no results...I think something is wrong with search (or me).
Anyway, I have a 1989 LWB with an auto that needs a rebuild. I would rather have a 5spd than an auto anyway (and don't want to spend $2000 for a rebuild). Are there any good threads on here for a swap?
1998 Mitusbishi Montero (winter package)
1987 Land Rover One Ten
Re: Swap an Auto for a 5spd [Re: dolomiti] #967381 10/12/09 12:51 AM
1
1986powerram50 Offline
Ive seen it done quite a few MMs not a montero tho. With the MM its a lil simpler w/ the cable clutch but basically all you have to do is install the tranny. Cut a hole thru the firewall reinforce the hole so the wall doesnt flex when you press the clutch. Rig up the cable and go.
Now with the montero being a hydro clutch everythings a lil more complex.
--keRby
Ad Inexplorta
Re: Swap an Auto for a 5spd [Re: dolomiti] #967382 10/12/09 01:04 AM
Mike_Pirie Offline
I am just completing this swap in my '92 gen 2. I didn't take a lot of pics, but took good notes along the way. I would guess your swap would be similar to mine; both are 3.0L engines. Please ask questions. I can scan my notes if you want them.
1992 montero, cranked t-bars, OME springs, 1-1/2" spring spacers, Homemade rear bumper and roof rack, 33" BFG AT, 1" body lift, Superwinch hubs, '95 SR locking rear axle, was AT - now V5MT1-3 5spd.
Re: Swap an Auto for a 5spd [Re: Mike_Pirie] #967383 10/12/09 12:26 PM
dolomiti Offline OP
Thanks, sending a PM.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6021 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-10-24 13:08:44 UTC
