Fuel pump go bad???? How can I test it quickly without pulling it? 22re #967448 10/12/09 02:07 PM
DJN Offline OP
87 22ret...ran great. I parked it out front of the house for a couple days and then went back to start it. Turns over fine and fires and runs for just a couple of seconds then dies out. Think it's the fuel pump, but just want to find out how to do a quick test. Thanks for any help!
Re: Fuel pump go bad???? How can I test it quickly without pulling it? 22re [Re: DJN] #967449 10/12/09 02:26 PM
4Crawler Offline
Re: Fuel pump go bad???? How can I test it quickly without pulling it? 22re [Re: 4Crawler] #967450 10/12/09 03:44 PM
Bolosh Offline
Just a note of caution... mine seemed to run fine using the test jumper, but I found that it was only putting out about 15 psi when I actually tested pressure with a gauge.
Re: Fuel pump go bad???? How can I test it quickly without pulling it? 22re [Re: Bolosh] #967451 10/13/09 07:14 PM
SALMONHEAD Offline
I used the pop bottle volume test.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5988 MB (Peak: 0.6542 MB) Data Comp: Off Server Time: 2026-11-03 19:31:55 UTC
