BF Goodrich KO tires #967452 10/12/09 04:27 PM
carook Offline OP
Was thinking about buying a set of these for my 4runner. Anybody familar with these tires?
Re: BF Goodrich KO tires [Re: carook] #967453 10/12/09 04:30 PM
G
Greg_Canada Offline
I've got 33x9.5's on mine for the winter and love them. Give you a couple more inches of ground clearance as well.
Now, if you want to float on the snow, you'll need 11.5" or wider. (9.5" cut through the snow and hit the ground). To me they are great all-year tires, however i would not use them for mudding. Everything else they handily outshine my bfg m/t km1's....
89 4Runner
Re: BF Goodrich KO tires [Re: Greg_Canada] #967454 10/13/09 02:31 AM
MAC Offline
The best all around tire I have ever used. Good traction. Quiet on the road. Wear well. No complaints. On my second set.
Re: BF Goodrich KO tires [Re: MAC] #967455 10/13/09 03:56 AM
Snowtoy Offline
The BFG AT's are perfect for a DD vehicle that sees mostly highway miles. They work great in the snow(floatation), rocks(preferably dry), sand, etc. As mentioned they aren't the best for mud, but work well enough on muddy logging/forest service roads, and shallow mud(few inches deep)
The last set of AT's(non KO) lasted 70k miles and still had legal tread when I swapped for my current set of KO's. BFG doesn't offer a mileage warranty, but if you rotate them every 3500-5k, keep the alignment correct, you shouldn't have an issue w/tread wear. If you have one near you. America's Tire Store has a '"No Questions asked" replacement warranty(used to), which makes it nice when you puncture a sidewall on the trail.
Re: BF Goodrich KO tires [Re: Snowtoy] #967456 10/13/09 04:49 AM
K_Raider Offline
I have a set of 30x9.50x15 on my Montero. They are wearing great. They still look brand new. I love them. <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: BF Goodrich KO tires [Re: carook] #967457 10/13/09 04:23 PM
carook Offline OP
Sounds like some good tires. Got me sold. Thanks for replys.
Re: BF Goodrich KO tires [Re: carook] #967458 10/13/09 07:04 PM
SALMONHEAD Offline
Add me to the list, I just had mine rotated and saw that I have 47k on them so far.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: BF Goodrich KO tires [Re: carook] #967459 10/14/09 06:14 AM
Ralph Offline
I love my set.
I'll buy nothing else.
Not great is deep slimy clay lake bottom mud with a crust on it.
Don't ask how I know.
Ralph
1991 Toyota 4x4 Standard Cab Pickup.
engnbldr cam and head.
Doug Thorley Headers
Home Made Cat Backs
30x9.5x15 BF Goodrich All-Terrain M/T KM2
Re: BF Goodrich KO tires [Re: Ralph] #967460 10/14/09 07:55 PM
4Crawler Offline
For an all around tire, I liked the 33x10.50 AT/KOs I ran on my '85:
- http://www.4crawler.com/4x4/BFG_AT_KO.shtml
Two downsides I found was that on gravel the tread tends to pick up ad throw lots of rocks, would be a problem with most any AT tread though. With MTs, I find almost no rocks thrown up under the truck. Also that tighter tread pattern seemed more prone to picking up road debris and causing flats. I think I had two flats on those ATs over their lifetime compared to none for two sets of BFG MTs.
But for pavement and in snow they were awesome tires.
Re: BF Goodrich KO tires [Re: 4Crawler] #967461 10/14/09 08:21 PM
1stgenboy Offline
I have had 2 sets on my '81. First set I got a 100k miles and served me well in socal. I bought a second set when I first moved to central Oregon and discovered they did not do well in the snow and mud and they must have changed the compound because they wore out in about 50k.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6385 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-06-07 01:36:25 UTC
