Re: Big Bill [Re: ryany] #967906 10/17/09 09:23 PM
Bernoulli Offline OP
I'm here (Bellingham) now. My son admitted that it looked like a slow month for his mechanic.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Big Bill [Re: 87Montero] #967907 10/18/09 01:34 AM
stony-man Offline
You could probably fly Brendan out there and get the work done for 2/3 that cost <img src="/forums/images/graemlins/lol.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" /> Sad, but it's true. I would love to take a trip to washington state, and my work is credible! <img src="/forums/images/graemlins/smile.gif" alt="" />
I'll vouch for that! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Big Bill [Re: stony-man] #967908 10/18/09 02:39 AM
3
300D50 Offline
This past summer a ticket was 315 round trip to sea-tac from jfk on northwest airlines for 1-3 week duration <img src="/forums/images/graemlins/wink.gif" alt="" />
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Big Bill [Re: Bernoulli] #967909 10/18/09 07:08 PM
There is some serious padding in that estimate.
It may well cost the $750 to change the timing belt, waterpump and seals on the engine.
But when in there the valve covers are about ¢ hour and $20 parts. He is hitting you real hard there.
I would confirm that you actually have a coolant leak. In 20K you sure should not need a waterpump and if you do I would look into the warranty on the previous one.
Cracked spark plugs, Interesting, does the engine run at this time? It must not if it has cracked spark plugs.
Is your battery bad?
Full tune up. Hoax. Just change your own plugs & wires. Even with ND Iridium plugs and good wires you will have $70 in that. At a slow pace it is an hours work.
The rear brakes last a long time on these. The drums can be tough to pull off if they are rusted on. Out your way they might not be rusted. But for him to claim you need new shoes he must have pulled the drums to check, Right.
All this work and I do not see any mention of greasing the truck. There are many grease fittings that need a squirt.
I would not consider this to be a trust worthy shop.
Re: Big Bill [Re: OldColt] #967910 10/21/09 04:47 AM
teal9550 Offline
A tune up is easy like everyone said 2hours tops, replacing the battery and terminal 15 min, rear brakes cake, he is taking you for a ride!!!! get a second opinion
Re: Big Bill [Re: teal9550] #967911 10/21/09 07:54 PM
My son had it tuned up. The idle is now 1200RPM. I'll attend to that and do the brakes next week when I get to Portland. Off to E.Oregon.....
Re: Big Bill [Re: Bernoulli] #967912 10/22/09 02:23 AM
KrzyDav Offline
sorry I haven't read all the post,,no time... but if you are concerned about the 1200 idle , I had this problem after having battery disconected. It was pointed out to me in the front of the FSM about resetting idle.start engine , run 5 min. click off and run another 5 min. Each time you do this the idle goes down about 100 rpm . got mine between 700-900. mine goes up and down a bit like a vacuum leak , but that's mine.
sorry if this isn't what your talking about , i'll delete it later..
dave h.
Re: Big Bill [Re: KrzyDav] #967913 10/22/09 03:27 AM
I've driven it several times, but I haven't done a 5 minute on/off thing. I'll check it out down the road.
Re: Big Bill [Re: Bernoulli] #967914 10/23/09 12:36 AM
KrzyDav Offline
It won't do it by driving, at least not right away.
You have to sit there and burn gas for 10-15 min.
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6380 MB (Peak: 0.7588 MB) Data Comp: Off Server Time: 2026-05-29 14:41:41 UTC
