High Beam Switch #968233 10/16/09 05:44 AM
F
FJR Offline OP
My high beam switch seems to not be working... any ideas?
Regular headlights work fine. If I pull the lever backwards the high beams will temporarily illuminate as normal. However, if I am on normal headlights and push the lever forward for high beams, I get no headlights at all. Total darkness.
What should I check first?
Thx
Re: High Beam Switch [Re: FJR] #968234 10/16/09 06:09 AM
kewlynx Offline
Make sure the headlight relay is working first; what's also common on Toys is the contacts for the switch get worn or dirty; that would be your next thing to check.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5867 MB (Peak: 0.6345 MB) Data Comp: Off Server Time: 2026-06-17 13:10:21 UTC
