Manual tranny shaft play
#968506
10/19/09 02:02 AM
A question for the tranny builders...........
I need to fix or replace the 5-speed tran in my 88 Montero. It's got a broken gear. I bought another trans from a salvage yard, same one, but the front shaft (input) has side-to-side play. I haven't measured it yet, but it seems like maybe 1/8" total. Any idea how much play is okay? The old tran has a much smaller amount of play. Thanks for any advice.
Re: Manual tranny shaft play
[Re: MADDOG]
#968507
10/19/09 02:40 AM
mine had a lot of shaft play as well and the bearing was shot. I would rebuild one of them before you put it back together. I'm in the process of doing this right now and its a pain in the butt
[Re: MADDOG]
#968508
10/19/09 04:12 AM
The input bearing would be shot with that much play.
[Re: teal9550]
#968509
10/19/09 03:35 PM
Thanks, guys. I've looked up the special tools for disassembly, and it's a lot of money. Does anyone know of a relatively inexpensive source, or maybe where I can rent?
Thanks.
[Re: MADDOG]
#968510
10/19/09 04:04 PM
You can get through these gearboxes without all the fancy tools.
[Re: OldColt]
#968511
10/19/09 04:22 PM
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6082 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-06-10 00:10:17 UTCValid HTML 5 and Valid CSS
