Manual tranny shaft play #968506 10/19/09 02:02 AM
MADDOG Offline OP
A question for the tranny builders...........
I need to fix or replace the 5-speed tran in my 88 Montero. It's got a broken gear. I bought another trans from a salvage yard, same one, but the front shaft (input) has side-to-side play. I haven't measured it yet, but it seems like maybe 1/8" total. Any idea how much play is okay? The old tran has a much smaller amount of play.
Thanks for any advice.
Re: Manual tranny shaft play [Re: MADDOG] #968507 10/19/09 02:40 AM
teal9550 Offline
mine had a lot of shaft play as well and the bearing was shot. I would rebuild one of them before you put it back together. I'm in the process of doing this right now and its a pain in the butt
Re: Manual tranny shaft play [Re: MADDOG] #968508 10/19/09 04:12 AM
The input bearing would be shot with that much play.
Re: Manual tranny shaft play [Re: teal9550] #968509 10/19/09 03:35 PM
MADDOG Offline OP
Thanks, guys. I've looked up the special tools for disassembly, and it's a lot of money. Does anyone know of a relatively inexpensive source, or maybe where I can rent?
Thanks.
Re: Manual tranny shaft play [Re: MADDOG] #968510 10/19/09 04:04 PM
You can get through these gearboxes without all the fancy tools.
Re: Manual tranny shaft play [Re: OldColt] #968511 10/19/09 04:22 PM
MADDOG Offline OP
Okay - I'll try! Thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6084 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-06-20 20:15:57 UTC
