Vehicross in Pick-A-Part!!! #968512 10/19/09 02:29 AM
FSJ1978 Offline OP
on Milliken in Ontario, CA. It's sitting in the fenced in yard and was part of the CARS program. Does anybody know if those vehicles can be licensed as salvage??? If I could get it cheap, I'd love to give it a new home... If not, I hope someone gets use of the body panels, windows, etc before they get damaged.
Chris Enos (Chino, CA)
'91 Isuzu Amigo "Rover" (Camaro 3800 swap in progress / 2.25" exhaust)
....(SOA / Custom rear bumper / CB / HAM)
Re: Vehicross in Pick-A-Part!!! [Re: FSJ1978] #968513 10/19/09 03:42 AM
JKrawler Offline
A moment of silence please.
_
_
_
_
_
_
As you probably already know, the engine in it is totaled, but everything else in the unit should be ok. Were you able to check it out at all, get the year, mileage, or check the body for rust?
My thinking is that if you can get the lot to sell it to you then you should be able to drop the body on a Trooper or SLX frame and drive train. Then either license it as a trooper or request a new Vin for it as a VX. As far as I know though the existing vin on that truck will never be active again.
Doing either of those will probably mean a lot of paperwork and $$$... if they will allow it.
If nothing else see if you can buy it as a parts truck and sell what you cant use on Kijiji or Craigs <img src="/forums/images/graemlins/wink.gif" alt="" />
Anyway, that's what I think.
93 Isuzu Trooper S w/ 3" Suspension Lift & 32" rubber.
94 Toyota Hilux Surf 3.0 TD,... more to come
Re: Vehicross in Pick-A-Part!!! [Re: JKrawler] #968514 10/21/09 05:22 AM
Triathlete Offline
If you were to drop it on another frame it would have to be the shorter RS.
Billy
VEHICROSS.INFO
'99 Vehicross 3"OME lift Torsion bar crank Ball joint flip 31" BFG AT's (everyday)/MTR's (wheel'n) Trooper skids OBA...more to come!
Re: Vehicross in Pick-A-Part!!! [Re: Triathlete] #968515 10/21/09 11:22 AM
JKrawler Offline
Or a carefully chopped and shortened one. The RS's are rare enough to want to keep 'em together if in good condition.
Re: Vehicross in Pick-A-Part!!! [Re: Triathlete] #968516 10/21/09 05:35 PM
lttlbddy Offline
It would probably fit on an Amigo/Rodeo Sport frame but then you would only have a 3.2 powerplant. And I bet the wiring harnesses and other electronics aren't the same between the 3.2 vs. 3.5
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6070 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-06-21 19:03:11 UTC
