proportioning valve #968693 10/20/09 02:01 AM
bill_grinder Offline OP
I had a rub through on a brake line. the brake warning light came on . I replaced the line and bled the brakes. the light is still on . how do I repair this? I have an 86 cj7 disc front and drum rear brakes.any help would be appreciated.
Re: proportioning valve [Re: bill_grinder] #968694 10/20/09 04:37 AM
BigJim Offline
I'd be bleeding them all around, real good, again.
Big JIm
Re: proportioning valve [Re: bill_grinder] #968695 10/20/09 11:21 PM
sunder Offline
If you have air up by the valve, you could crack the valve loose while someone puts light pressure on the braking system. Once all the air is out and good clean fluid come out, just tighten it back up.
91 YJ
2 Seater Sand Rail
Handfull of other fun toys...
And a brand new, spit shined, B.S.
Oh, and a job to boot.
Re: proportioning valve [Re: sunder] #968696 10/24/09 01:56 AM
rixcj Offline
Just make sure that you have the little button on the proportioning valve pressed in, while bleeding.
Rich
'79 CJ5,401,t-18/d20,dana30/amc20(Mosers),GM HEI, Edelbrock Performer intake,Holley 600, ps/pb, 'glass tub/1pc. tilt nose, 33x12.50x15 BFG T/A's. Lots more to be done...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5995 MB (Peak: 0.6546 MB) Data Comp: Off Server Time: 2026-06-07 04:18:18 UTC
