V6 Fuel pump cage #968802 10/20/09 04:45 PM
87_Montero Offline OP
This is for a 1989 V6.
My fuel pump works, but the center tube or hose nipple on the top of the cage (fuel pump assembly) has broken off. A fuel pump assembly, without a working pump, is probably what I need. My 4x4wire inbox is full, but you can email me at [email]bob.wilson.tn@gmail.com.[/email]
Thanks,
Bob
DDs:
Projects: 86 Ram50
Re: V6 Fuel pump cage [Re: 87_Montero] #968803 10/20/09 09:23 PM
V
vr4 Offline
i have one from a 91 LWB. not sure if it interchanges. ill have to look into it.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: V6 Fuel pump cage [Re: vr4] #968804 10/21/09 05:20 PM
You have exactly what I need! The fuel pump assembly I have in the 1989 right now - and that I just messed up - came out of a 1991 LWB. The two models use the same fuel pump and assembly.
DDs:
Projects: 86 Ram50
Re: V6 Fuel pump cage [Re: vr4] #968805 10/21/09 05:23 PM
91 Stealth with 18G Turbos?
Incredible! That must really fly!
DDs:
Projects: 86 Ram50
Re: V6 Fuel pump cage [Re: 87_Montero] #968806 10/21/09 08:58 PM
V
vr4 Offline
90 shipped? it looks near mint other than being dirty. no rust at all.
the stealth? its quick. it helps that its gutted and weighs in around 2900 lbs.
91 MR2 turbo
Re: V6 Fuel pump cage [Re: vr4] #968807 10/22/09 09:10 PM
pm sent
DDs:
Projects: 86 Ram50
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6070 MB (Peak: 0.6759 MB) Data Comp: Off Server Time: 2026-11-02 14:15:20 UTC
