Frame change #969462 10/25/09 12:24 PM
shovelhead Offline OP
I'm having mine done right now, they gave me a 2009 taco as a loaner, its a 5 spd now I've got the bug to get back into a stick vehicle. Does anybody know if the 3.4 crank is bored to accept a pilot bearing?
With enough time and enough money ya can fix anything
Re: Frame change [Re: shovelhead] #969463 10/26/09 03:50 AM
G
Greg_Canada Offline
The 97 4runner auto 3.4 i got my donor for my engine swap (to 5spd) was machined for it.
I dont see why they would not have done it, why make 2 different crankshafts when everything else is the same?
89 4Runner
Re: Frame change [Re: Greg_Canada] #969464 10/26/09 11:39 PM
thanks Greg, the early small block chevys had 2 different cranks. now all I've got to do is find a donor
Re: Frame change [Re: shovelhead] #969465 10/27/09 07:28 PM
G
Greg_Canada Offline
I've heard it's like a 1% chance to find one not drilled for a pilot bearing, but even if it's not, it's not too difficult to remove the crank when the engine's on a stand, you should be replacing the water/oil pump and rear main seal anyways.
89 4Runner
Re: Frame change [Re: Greg_Canada] #969466 10/28/09 12:40 AM
don't plan on pulling the mill just swinging in a 5spd
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6038 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-10-21 18:53:28 UTC
