Frame change
#969462
10/25/09 12:24 PM
I'm having mine done right now, they gave me a 2009 taco as a loaner, its a 5 spd now I've got the bug to get back into a stick vehicle. Does anybody know if the 3.4 crank is bored to accept a pilot bearing?
With enough time and enough money ya can fix anything
Re: Frame change
[Re: shovelhead]
#969463
10/26/09 03:50 AM
The 97 4runner auto 3.4 i got my donor for my engine swap (to 5spd) was machined for it. I dont see why they would not have done it, why make 2 different crankshafts when everything else is the same?
89 4Runner 3" BL, M/T locks, 33"bfg mt, bilstein, Kayline, tubebumper, toyotafiberglass panels TBI: Elocker,3.4 w/ORS,b+b,S2Sstg2cams,arias pistons,P+P intake,TRDs/c,URDpullies+7th,downey headers,MAPECU2,WEGO WB, SupraMAF,walboro255,stg4clutch, EPaOo2 sim
Re: Frame change
[Re: Greg_Canada]
#969464
10/26/09 11:39 PM
thanks Greg, the early small block chevys had 2 different cranks. now all I've got to do is find a donor
Re: Frame change
[Re: shovelhead]
#969465
10/27/09 07:28 PM
I've heard it's like a 1% chance to find one not drilled for a pilot bearing, but even if it's not, it's not too difficult to remove the crank when the engine's on a stand, you should be replacing the water/oil pump and rear main seal anyways.
Re: Frame change
[Re: Greg_Canada]
#969466
10/28/09 12:40 AM
don't plan on pulling the mill just swinging in a 5spd
