99 sport into 93 max #969561 10/26/09 06:34 PM
mitsumonki Offline OP
will a 99 sport 3.0 bolt to the 93 3.0 trans?
Re: 99 sport into 93 max [Re: mitsumonki] #969562 10/27/09 02:26 AM
1
1986powerram50 Offline
Should let us know how it works out tho!!
--keRby
Ad Inexplorta
Re: 99 sport into 93 max [Re: 1986powerram50] #969563 10/27/09 02:32 AM
StockRaider Offline
All 3.0 3.5 and 3.8 blocks have the same bellhousing and motor mount mounting locations. So yes, from what I have seen it should bolt in. BUT the biggest problems you would have is the electronics matching up. might have to use the MM intake.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 99 sport into 93 max [Re: mitsumonki] #969564 10/27/09 02:43 AM
KrzyDav Offline
I thought about useing the 24 valve quite a few years back, untill I learned of all the stuff I'd have to do, esp. in CA to meet emmissions.
Whole wiring harness and ECU and stuff like drilling/ welding 4 O2 sensor mounts for the 24valve setup.
If I was gonna go to all that trouble I'd get the 3.5 or 3.8 SOHC.
dave h.
Re: 99 sport into 93 max [Re: KrzyDav] #969565 10/27/09 04:53 AM
yeah 3.5 would be nice but i might get a good deal on a whole sport that was rolled
Re: 99 sport into 93 max [Re: mitsumonki] #969566 10/27/09 06:34 PM
That 99 Sport engine will bolt up to the bellhousing fine. The side mounts may be a bit different though and may need some mix& match to bolt up.
That swap will make a nice driving pickup.
Re: 99 sport into 93 max [Re: OldColt] #969567 10/28/09 02:04 AM
1
FYI: I was told by a fellow on outerlimits, that the 6g72 and 6g74 have slightly different mounts. That require some modification.
--keRby
Ad Inexplorta
Re: 99 sport into 93 max [Re: 1986powerram50] #969568 10/29/09 11:25 PM
well i bought it and started tearing it down
the big harness up to is the ecm harness the bottom one is for the dash switches and junk
[Linked Image] [Linked Image] [Linked Image] [Linked Image]
Re: 99 sport into 93 max [Re: mitsumonki] #969569 10/29/09 11:31 PM
so my plan is to have complete obd2 with the bigger sport gas tank and evaporate system.
what else should i try and swap over?
I was thinking power door locks would be nice <img src="/forums/images/graemlins/smile.gif" alt="" />
the front wishbones are toast but the brakes seem ok.
are they bigger?
Re: 99 sport into 93 max [Re: mitsumonki] #969570 10/29/09 11:43 PM
KrzyDav Offline
I look forward to you doing a "how to" ... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Maybe someday I'll do something like that , that is if I can move outta CA.
I'm still getting by with my crank snout damaged 3.0 12 valve. When the leaks finally cause my T-belt to break or bearings to seize maybe I'll do a 3.5 SOHC. I find more wrecked 2wd M.S.s than other mitsus in the yards anyway.
God luck <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
dave h.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6415 MB (Peak: 0.7650 MB) Data Comp: Off Server Time: 2026-06-07 04:40:10 UTC
