Page 1 of 3 1 2 3
How to replace ATF in Montero #969580 10/26/09 10:10 PM
Alex Kogan Offline OP
Proper ATF replacement procedure is quite simple actually.
So here it is:
Raise you vehicle slightly. You need decent size vessel to fit under.
Disconnect ATF return line at cooler (line #2 on diagram).
This diagram applies to Gen 2 Montero only but others (Sport, Gen 1, Gen 3) should be very similar.
Direct it into your catch container via funnel like I did or attach longer hose in it's place. Even clear vinyl tubing out of Home Depot will do.
Shift your AT into neutral. Make sure your drain fixtures are not going to fly around. Turn on your engine and let idle for 30 sec to 1 min (NOT MORE). This will pup out whatever fluid can be picked up from AT sump out into that container.
Shut off engine.
Drain remaining ATF from transmission sump vi drain plug.
Install the drain plug back and tighten it. Do not do anything with container upfront yet.
Now there is still a little fluid left in transmission internals.
To pump that out add maybe 4-5 quarts of NEW ATF to transmission vi measuring stick tube. Don't worry about overfilling yet.
Turn on the engine again (transmission still in Neutral(N) not P. This will pump out rest of old ATF and replace it with new fluid. Some of new fluid inevitably will be lost but that's the price.
Remove that catch container and put everything upfront back together. Add ATF to required level. Don't forget that you have check fluid level with running engine and transmission in Neutral not P. Enjoy smooth shifting transmission once again.
Now on that screen filter. IMHO there is no good reason to replace (I assure you dealer won't do anything about it) or wash it unless there was a problem with transmission fluid (burned smell, weird color etc) or your transmission overheated etc.
This procedure has pretty much exactly effect (and works) as dealer's mythical ATF changing machine. And no, they don't use and detergent, I personally wouldn't want them to anyway. If there is a problem requiring special cleaning washing it probably means you have something bigger to worry about. Properly functioning hydraulic systems are always very clean inside.
08 PowerWagon (stock!)
Re: How to replace ATF in Montero [Re: Alex Kogan] #969581 10/26/09 11:40 PM
Oyaji_Jon Offline
Thanks for posting this, Alex. It's on my list of things to do since I have already dumped the torque converter fluid and it will be fresh when I put it back in.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: How to replace ATF in Montero [Re: Alex Kogan] #969582 10/27/09 12:24 AM
NICE!! Added to FAQ thread! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: How to replace ATF in Montero [Re: off-roader] #969583 10/27/09 12:28 AM
FrankR Offline
Good procedure! <img src="/forums/images/graemlins/kewl.gif" alt="" />
That should get most of it.
Frank
Re: How to replace ATF in Montero [Re: FrankR] #969584 10/27/09 05:12 AM
Angelo Offline
Good explaination! So how do you determine how long to run it, 30 to 1 min? And by pitting the truck on N, the truck will not turn over, correct?
Thanks for sharing!!
Re: How to replace ATF in Montero [Re: Angelo] #969585 10/27/09 05:37 AM
Oyaji_Jon Offline
The engine will start in neutral. I think having it in neutral aligns the valves in a way that will allow fluid to cycle through the valve train instead of just recirculating (in Park). I'm sure someone of much more knowledge than me has more info for you on this, though...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: How to replace ATF in Montero [Re: Oyaji_Jon] #969586 10/27/09 05:47 AM
Using a clear drain tube off the cooler will tell you when the fluid starts to run out clean. That'd be when I would shut it down.
Re: How to replace ATF in Montero [Re: JohnnyBfromPeoria] #969587 10/27/09 12:30 PM
Mad_Scientist Offline
Another good reason to not pay people to work on my truck <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Great write-up Alex. I'll be doing it this way from now on <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: How to replace ATF in Montero [Re: Mad_Scientist] #969588 10/27/09 04:18 PM
With running engine fluid will pump out very quickly. You can hear it going. Point is not to run it for too long without fluid. If you hear(see) it stopped pouring out in less than a minute then turn off engine. I will be surely gone in 1 minute.
Point on detergent is that if it's not broken don't fix it. I would likely do more harm than good.
Re: How to replace ATF in Montero [Re: Alex Kogan] #969589 02/21/10 05:28 AM
scottiesharpe Offline
Hey thanks for this post. I used your technique and it worked like a charm. Got the fluid flushed and changed in just 30 min!
Scottie Sharpe
Sunny San Jose CA
Webmaser for BMW TURBOS! Forum
http://bmwturbos.scottiesharpe.com
1995 Montero SR
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6486 MB (Peak: 0.7708 MB) Data Comp: Off Server Time: 2026-07-09 20:39:33 UTC
