5 speed interchange #969794 10/29/09 01:48 AM
teal9550 Offline OP
So I'm trying to figure out what other 5 speed trans my interchange with my 87 4cly montero, dodge radier I assume, how about a D50 pickup or a mighty max or something else. Im cheap and would like to get one from a jy if I can. any thoughts?
Re: 5 speed interchange [Re: teal9550] #969795 10/29/09 01:50 AM
If it's got a tag on the side that says KM145, it will work, as long as it's in a 4wd truck.
Re: 5 speed interchange [Re: fasteddy] #969796 10/29/09 02:18 AM
powerRam50 Offline
no the trucks wont work.they have a cable clutch setup and the Monty has a hyd setup.so the bell housing is different and you cant change the bell housing.
Re: 5 speed interchange [Re: powerRam50] #969797 10/29/09 02:21 AM
teal9550 Offline OP
so it has to be a monty or raider only then. those are tough to find cheap
Re: 5 speed interchange [Re: teal9550] #969798 10/29/09 02:36 AM
There's a reason for that. Seems like they should have made two for every vehicle produced... Or made them so they wouldn't need to be replaced/rebuilt as often. I know I went through a couple on my '87 manual Raider...
No more of those for me, at least until I rebuild one myself with all of Kevin C's/FastEddy's and the other smart guys around the 4x4 Wire's tricks.
Re: 5 speed interchange [Re: teal9550] #969799 10/29/09 02:45 AM
haztoys Offline
So any thoughts?
It some point your (you all) are going to have to rebuild a trans ..This just consume a trans then find a used one cost more to you and the car world then you ever save ... We all want to go cheap... I know ..
You will be happyer in the long run ..
Sorry if my way of looking at it is not like most..
David
Hazardous Toys inc
Re: 5 speed interchange [Re: haztoys] #969800 10/29/09 04:32 AM
teal9550 Offline OP
I was planning to rebuild it and I will, it's torn down I will order the parts I think I can get a bearing & seal kit for about 150. This car started as a cheap project and turned into more money than I wanted to spend. oh well i hope its worth it in the end
Re: 5 speed interchange [Re: teal9550] #969801 10/29/09 02:04 PM
Look up KevinC's remarks on rebuilding the 5spd and the late model parts to use. They did a fair job of beefing up the internals for the Starion/Conquest late model (88-89) 5spds to handle the added torque of the turbo. Should help quite a bit.
Re: 5 speed interchange [Re: fasteddy] #969802 10/29/09 11:30 PM
MADDOG Offline
Can you tell me how to find KevinC's stuff on the rebuild? I can't get the search to give me anything. Thanks.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6278 MB (Peak: 0.7147 MB) Data Comp: Off Server Time: 2026-05-29 16:13:30 UTC
