throwing codes while driving #969814 10/29/09 02:12 AM
mgd4me Offline OP
what would make the ecu throw codes while driving? could it be my water crossing(you tube...sunken Toyota). my ecu may have, probably got a Lil wet. i know the fuse block under the hood had moisture in it. could it be just a fuse? could i have blown the ecu?and yes i drove it home after a fluid change. only thing is i now need a clutch due to a bad oil filter. i think earl got into the clutch.
the codes are 14,21,52, and 71...14- igf signal.21- o2 sensor,52-knock sensor, and 71- egr system
Re: throwing codes while driving *DELETED* [Re: mgd4me] #969815 10/29/09 02:16 AM
mgd4me Offline OP
Post deleted by mgd4me
94 ex cab 3" body...33" bfgs... 1 roll over..stocker
http://www.youtube.com/watch?v=tYlDedAt96Y
Re: throwing codes while driving [Re: mgd4me] #969816 10/29/09 02:22 AM
4Crawler Offline
You can pull the stored code(s) and see what they are:
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#TimingCheckConnector
Re: throwing codes while driving [Re: 4Crawler] #969817 10/29/09 02:37 AM
mgd4me Offline OP
stored codes are the same...14,21,52, and 71... i pulled the ecu fuse and the battery....no chance...
Re: throwing codes while driving [Re: mgd4me] #969818 10/29/09 04:14 AM
4Crawler Offline
Well if those codes are coming back, it could either be they are real or the ECU is bad. Pretty easy to check some of those, the O2 sensor heater circuit is either good or bad (ohm meter to test), the EGR temp sensor is similar, might be a clogged EGR preventing the sensor from reading hot enough. Knock sensor may be a bad wire, etc.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6068 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-10-21 19:15:48 UTC
