Page 3 of 4 1 2 3 4
Re: Gas mileage? [Re: ryany] #969887 11/01/09 05:10 PM
Bernoulli Offline
On my current trip through the PNW, I pushed 20mpg at 75 on Washington gas, but the E10 in Oregon has dropped it by 10%.
I don't get it. I use the same amount of gas plus I have to burn water loving ethanol which cost more global warming to produce as well as driving up world wide commodity prices etc., etc.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Gas mileage? [Re: Bernoulli] #969888 11/01/09 05:48 PM
P
pcc Offline
You always have to expect less mileage with ethanol in the gas. I easily get 20+ mpg hwy at about 70mph without ethanol gas, with ethanol you'll get at least 10% less mileage. So that cheaper price for ethanol (subsidized) gas is bogus. I calculated I could get the same dollars or better per tank for non-ethanol gas for a price up to about 10 cents more per gallon. But I have no non-ethanol choices now that the local Amoco/BP caved in and stopped selling non-ethanol gas. Thank those corn state congressmen and the ag industry. Let's see, using land for gasoline instead of food - yea that makes sense.
Re: Gas mileage? [Re: Bernoulli] #969889 11/01/09 06:45 PM
Kevin C Offline
I'm pretty pro enviorment and have all the emmisons equipment intact even though I added a turbo (EGR, Cat and pulse air system), but I cant get behind ethanol gas.
I also think it affect some of the older vehilce a bit more since that carb vehicles dont compensate for fuel changes as well. I also think that the lower turbulance hemi style engines might be bit morea affected by the slower flame speed of the ethanol mix ( 2.6).
Around town its hard to get much more than 14 -15 on my Raider. On the highway 18 to 21 is typical. I have gotten 20+ mpg long highway trips, as long as the AC was off. I averaged agou 75 mph. The AC seems to drop the fuel economy by 1-2 mpg.
I also trrned the boost down from 14 or so PSI to around 11, that seems to have helped. On the turbo I think that a by pass valve would improve fuel economy, I just need to get around to setting one up.
Kevin
Re: Gas mileage? [Re: Kevin C] #969890 11/01/09 10:28 PM
KrzyDav Offline
Another need for campaign finanance reform,,,and a Guillontine on wall street. Multinational Corps owning Congress and perpetuating the "Ethanol Myth".
What's the ratio of fuel burned to make a gallon of ethanol , like 1.0 gallons of petrolium to make a 1.5 of ethenol.
dave h.
Re: Gas mileage? [Re: KrzyDav] #969891 11/01/09 10:52 PM
IIRC, alcohols have roughly half the btu's per gal. as gasoline. I know that alky carbs have jets about twice the xsect. area of gas jets. We used to overdrill gas jets with a drill size about 1.4x the original jet diameter (sqrt of 2 is 1.44ish) when converting to alky on round track cars and dragsters.
Therefore, if you're burning gasahols, your power and mileage will go down. It always looked like a case of ecological correctness geting in the way of good engineering. Mistrust all radicals. They don't let either science or common sense get in the way of ideology...
Re: Gas mileage? [Re: fasteddy] #969892 11/03/09 05:47 PM
RocLimer Offline
I just got the best highway only mileage this last weekend, 19.92 miles per gallon on Highway 1 and Sir Francis Drake Blvd out near Tomales Bay and Bodega Bay this last weekend.
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Gas mileage? [Re: RocLimer] #969893 11/04/09 03:05 AM
O
OneTime Offline
Roclimer. To think I used to get paid to patrol Sonoma Co. Man do I regret leaving that place. OK Hickjack off....
98 Gen 2.5 w/ winter package & 31x10 BFG ATs.
Re: Gas mileage? [Re: OneTime] #969894 11/04/09 06:39 PM
ejm Offline
I just drove cross country to LA. and i got between 16.7-18.5 mpg.
That was on 265/75/16 stock roof rack. My avg speed was over 73 mph the trip. Made it from Ocean City,NJ to Santa Monica,Ca. in 57 hours.
98 Montero, OME lift, Girvin Systems roof rack, Custom Discovery rear ladder 285/75/16 Mickey Thompson MTZ, Cepek DC-1 16x8
Re: Gas mileage? [Re: ejm] #969895 11/05/09 10:28 PM
KrzyDav Offline
I went ahead and took my Conferr off for the season. I mainly use it to keep the sun off my roof,,,the dog stays cooler that way. Seems I have my power back, that thing makes for alot of wind resistance.
dave h.
Re: Gas mileage? [Re: KrzyDav] #969896 11/06/09 03:27 PM
cdl1701 Offline
I have run my MPG 4 times now and am getting 20-22 every time on my 88 2.6.
running 255/75s now but getting ready to put some 31x10.5 on this weekend... wonder what that will do to my MPG?
88 Montero, 2.6 Black
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6419 MB (Peak: 0.7669 MB) Data Comp: Off Server Time: 2026-05-29 15:27:25 UTC
