brakes #969941 10/30/09 03:59 PM
snowboardvdr Offline OP
had some ruff noise from the brakes, so i went to brakeworld.com and got the same set as one of our fellow sporty driver. i ended up getting a new pass caliper, caliper bolt was stripped. it came out easy.lol. i still have the noise tho, there is a little damage to the wheel. my gf later told me she hit a curb. what do u guys think? wheel bearings? <img src="/forums/images/graemlins/frown.gif" alt="" />
if speed kill do brakes give life?
Re: brakes [Re: snowboardvdr] #969942 10/30/09 05:56 PM
6
69442 Offline
Sounds like a possible bearing failure, can you describe in more detail what your doing when you hear the noise and what makes it go away if at all. In my experience bearings can be noisy w/o doing anything at all. Or you hear it during braking and usually while turning which typically identifies the outside bearing as the failed one. Any other odd things like vibration or pulsation while braking?
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: brakes [Re: 69442] #969943 10/31/09 12:57 AM
yea i kinda left out alot huh.. it happens only when i brake, or when i turn to the right but its not to loud. novibration or pulsation while braking. just changed both inner and outer bearings last winter. the curb rash on my wheel is about 4"long. it dont look bad. Also im gonna b getting 235 75 15 tires. how much of the front bumper do i have to trim and whare do i have to do it. pics? I just picked up 2 jeeps and i have these tires. im going to 33" on the cherokee. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: brakes [Re: snowboardvdr] #969944 10/31/09 08:00 AM
2002_Sporty Offline
Look on the first thread up at the top of the forum. There are many good references in that thread. I left three links with good visuals on the wheel clearence on page 3. I have a 3" UPYOURKIA lift, but that dosen't make a big difference. I'm sure you won't have to make any trimming to the bumpers at that size tire. But it will look alot better than it did.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: brakes [Re: 2002_Sporty] #969945 11/03/09 04:29 PM
im doing the bearings prob thursday. Maine state law says i can only go 2 tire sizes up or no more than 2" over stock. <img src="/forums/images/graemlins/cheers.gif" alt="" />I have extra rim's so i will put them on after inspection. i wanted to lift it but my son needed a ride. I got both jeeps for 2grand. 95 cherokee n 98 grand cherokee. the guy was getting stationed over seas and had to dump them quick. I love the sporty the best tho. thanks for the help guys!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: brakes [Re: snowboardvdr] #969946 11/14/09 05:20 AM
ok,..the rear brake cylender blew! so im doing the drums, any tips? advice, ive never done drum's b-4. HELP!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: brakes [Re: snowboardvdr] #969947 11/14/09 05:06 PM
Everet Offline
Always had my dad help me do the drum brakes. Sure do miss him.
Anyway, was wondering how you like the front brake pads. Did you get the Ti coated Kevlar ones? I really noticed a better feel and less pedal pressure than the previous set on my sportage.
Re: brakes [Re: snowboardvdr] #969948 11/15/09 12:55 AM
bombardj1 Offline
always replace both cylinders, the samething goes for calipers, some just replace 1 but it time 1 might grab firstpulling the car that way and people wonder why.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: brakes [Re: bombardj1] #969949 11/15/09 03:37 AM
jays2001 Offline
check the kiatech site and take one apart at a time that way u have one to reference if u forget how it came apart or take pics of it before taken apart
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: brakes [Re: jays2001] #969950 11/15/09 03:40 AM
jays2001 Offline
ooooooooooo yea mine was a pain to take the drum off but i think that was due to pads coming off the shoe and locking them up but other than that they are easy.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6395 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-10-22 02:14:47 UTC
