2.6 Distributor Will Not Slide In All The Way #970519 11/03/09 03:25 AM
republic Offline OP
Just swapped the head on my 1991 Rodeo. The distributor from the original head will not snug up all the way on the replacement head, there's about an 1/8 inch gap. What am I missing?
Thanks,
Phil
Raised By A Wolf
Re: 2.6 Distributor Will Not Slide In All The Way [Re: republic] #970520 11/03/09 05:27 PM
Trooper-san Offline
Just guessing here, taking some shots in the dark.
What is the replacement head? Where did it come from? What year?
As I recall there is an 'O' ring on the shaft. Did you give it plenty of lub so it could slip in? The final seating might be a bit of a push.
Could it be a problem with the gears not quite lining up? It seems unlikely if it's out only 1/8th inch.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: 2.6 Distributor Will Not Slide In All The Way [Re: Trooper-san] #970521 11/03/09 07:48 PM
republic Offline OP
Thanks for the post. The gears mesh, the dist turns free no binding at all. The old head was a #2 this one is a #1.
I know, not the best choice. but it will do till I can do a 3.1/3.4 swap. I bought the head for cheap. It came with all the papers, had been rebuilt eleven years ago and sat on a shelf at a garage. I did replace the valve stem seals since it was built so long ago.
I had lightly lubed the O-ring with grease and this morning with spray lube. Now the gap is about 1/16". Maybe it's a slight casting difference between a #1 and #2.
For now I'm going with it.
Thanks,
Phil
Raised By A Wolf
Re: 2.6 Distributor Will Not Slide In All The Way ***UPDATE*** [Re: republic] #970522 11/11/09 01:26 AM
republic Offline OP
Put on a new O-ring lubed it good and the dissy pulled in snug as I tightend the top adjusting nut. Thanks.
Phil
Raised By A Wolf
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6006 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-07-16 03:40:37 UTC
