2.6 Distributor Will Not Slide In All The Way
#970519
11/03/09 03:25 AM
Just swapped the head on my 1991 Rodeo. The distributor from the original head will not snug up all the way on the replacement head, there's about an 1/8 inch gap. What am I missing?
Thanks,
Phil
Raised By A Wolf
Re: 2.6 Distributor Will Not Slide In All The Way
[Re: republic]
#970520
11/03/09 05:27 PM
Just guessing here, taking some shots in the dark.
What is the replacement head? Where did it come from? What year?
As I recall there is an 'O' ring on the shaft. Did you give it plenty of lub so it could slip in? The final seating might be a bit of a push.
Could it be a problem with the gears not quite lining up? It seems unlikely if it's out only 1/8th inch.
1989 Trooper, 2.6 1989 Trooper, 2.8 1992 Ford F-350, 7.3 My Photos
[Re: Trooper-san]
#970521
11/03/09 07:48 PM
Thanks for the post. The gears mesh, the dist turns free no binding at all. The old head was a #2 this one is a #1. I know, not the best choice. but it will do till I can do a 3.1/3.4 swap. I bought the head for cheap. It came with all the papers, had been rebuilt eleven years ago and sat on a shelf at a garage. I did replace the valve stem seals since it was built so long ago.
I had lightly lubed the O-ring with grease and this morning with spray lube. Now the gap is about 1/16". Maybe it's a slight casting difference between a #1 and #2.
For now I'm going with it.
Thanks,
Phil
Raised By A Wolf
Re: 2.6 Distributor Will Not Slide In All The Way ***UPDATE***
[Re: republic]
#970522
11/11/09 01:26 AM
Put on a new O-ring lubed it good and the dissy pulled in snug as I tightend the top adjusting nut. Thanks.
Phil
Raised By A Wolf
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6020 MB (Peak: 0.6580 MB) Data Comp: Off Server Time: 2026-07-16 03:40:02 UTCValid HTML 5 and Valid CSS
