driver's side outer tie rod end--two in a year #970622 11/04/09 03:02 AM
W
wizardz Offline OP
For some reason, I'm going through driver's side outer tie rod ends. The first (Moog) failed after only 10 months and less than 8k miles. The last (TRW) failed tonight after 3 months. Pennsylvania roads are notoriously bad, for what it's worth. That said, I suspect another problem. In the last year I replaced inner and outer rods and sleeves on both sides, as well as idler arm and pitman arm and ball joints all around. I can't understand what else could be causing this. Do you guys have any ideas? Are the quality of Moog and TRW parts really that bad?
<img src="/forums/images/graemlins/evil.gif" alt="" />
*95 T100, 4WD, EXTCAB, SR5, 5spd, 2.5 mm bored throttle body, Kumho Venture MT, Bilstein HD, TRD SC, URD Performance Upgrade Kit, 2" body lift, TRD headers coming soon
*06 Toyota Rav4 269HP 4wd V6
Amsoil in all
Re: driver's side outer tie rod end--two in a year [Re: wizardz] #970623 11/04/09 03:13 AM
CJMT100 Offline
Moog is the best usually. How is the part failing, is it just wearing out on the ball and socket? Could something have gotten inside the rubber boot?
Re: driver's side outer tie rod end--two in a year [Re: CJMT100] #970624 11/04/09 04:27 AM
W
wizardz Offline OP
the boot seems to split and ooze grease. Which brings up the question, how much grease should you load into the joint at install time?
Amsoil in all
Re: driver's side outer tie rod end--two in a year [Re: wizardz] #970625 11/04/09 04:36 PM
ErikB Offline
Toyota Moderator
Oozing grease doesn't mean its failed...?
You just need enough grease in there to keep it wet/lubricated. More isn't better, especially if its splitting boots.
Moog should be good from what I've heard, but its hard to beat OEM Toyota stuff. I've got over 270k on my original TRE's.
http://home.4x4wire.com/erik
Re: driver's side outer tie rod end--two in a year [Re: ErikB] #970626 11/04/09 05:11 PM
W
wizardz Offline OP
No, oozing grease doesn't mean it failed, but when the boot is split and there is play in the joint, it means it failed and that has been my experience. When the Moog joint failed, it was almost impossible to keep the truck on the road at speeds > 50MPH.
Amsoil in all
Re: driver's side outer tie rod end--two in a year [Re: wizardz] #970627 11/04/09 08:35 PM
BamZipPow Offline
Got any piccies of yer front suspension? Not sure if you don't have some other problem at hand. Any loose/broken bolts/parts in the suspension?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6090 MB (Peak: 0.6787 MB) Data Comp: Off Server Time: 2026-05-28 01:05:24 UTC
