Page 3 of 6 1 2 3 4 5 6
Re: Strengthening KM145 5 speed [Re: 0778drz110] #970648 11/06/09 11:56 PM
V
vr4 Offline
i just moved to a V5MT1
smile
explain.
im partial to the V6 <img src="/forums/images/graemlins/smile.gif" alt="" />
granted the entire truck needs some serious work (stuck in 3rd, t-case chain is jumping due to 2G front hubs installed, rear axle is leaking, bad engine)
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: Strengthening KM145 5 speed [Re: MontyMcV] #970649 11/07/09 01:24 AM
87Raider_TSI Offline
Later on I found out that the Starion trannies came with a cast pan. I liked mine better since it held about a 1/2 qt more lube.
Damn, I threw away a Quest tranny after I cannibalized it for the OD gear and tailshaft bearings that time when mine threw the back nut. Would have swapped the cast cover over...
Only the later Starion transmissions have the cast AL pan. 83-87's had a stamped pan like the KM145.
'87 Raider SWB 2.6T/5 spd - Boxy and boosted.
'88 Conquest TSI - MPI and lots of other mods
Re: Strengthening KM145 5 speed [Re: 87Raider_TSI] #970650 11/07/09 01:37 AM
plh Offline OP
Good discussions with the machinist today, but it will be Monday before I have all the costs available.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Strengthening KM145 5 speed [Re: 87Raider_TSI] #970651 11/07/09 03:33 AM
Kevin C Offline
I forgot to mention that, thanks. Interestingly they started using them when they upped the boost and the torque.
Kevin
Re: Strengthening KM145 5 speed [Re: plh] #970652 11/08/09 11:35 PM
Angel Carlo Offline
I may be interested in one. I'm planning to go to a bigger turbo. Perhaps an 18G. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1987 Dodge Raider rebuilt Quest block bored .040 over put together, and installed by Shelby. 5spd, '87 stock turbo, Intercooled, 2.5" exhaust. MPI with hard pipes, FIP Pro-4, MSextra MS1
Re: Strengthening KM145 5 speed [Re: Angel Carlo] #970653 11/10/09 06:22 AM
spencevans Offline
I would be interested in one of these for my KM132. The KM145 trannies are much more suseptable to failure than the KM132 because when you put power through the tcase they tend to twist. But I think both trannies would greatly benifit.
I have never had any issues with running a KM145 behind my 2.3 diesel and it puts out alot more torque than stock. My complaint has always been the clutch, not the tranny. I blow through clutches every 40k miles. I went with a Centerforce II clutch recently and "Wow" what a difference. It sure puts the power to the wheels. I just hope it lasts.
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Strengthening KM145 5 speed [Re: spencevans] #970654 11/10/09 08:59 PM
0778drz110 Offline
So would a good cross member that bolts to the tcase a,d/or tranny help? I would think it would? You could make a nice skid with it too...
Re: Strengthening KM145 5 speed [Re: 0778drz110] #970655 11/11/09 01:42 AM
plh Offline OP
I received a quote back from one of the machine shops I am working with. Completely out of sight. Asked him for some VA/VE ideas and still discussing with a second source.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Strengthening KM145 5 speed [Re: powerRam50] #970656 11/11/09 02:31 AM
N
NickR Offline
Off Topic
My brother use to work at Klune about 10 years ago, back before I was into off road and had access to the machine shop and engineers. On one occasion the counter top of my stove was damaged during my move, he took it to work and returned it to me looking like new. At work I had a Mac and he created a custom "stand" so I could attached to my desk, all for free. A couple weeks back talking to my brother about the Mohave trip, he tell his story about when he work at Klune that he use to due side project for the founders son who was into rock crawling and they were at that time doing R&D on the Klune-v transfer cases and going out to the "dessert" to test it out. If only he still work there the possibilities for my Raider.
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage
SR Axle
LSD 3rd member
Early Gen 1 Bouncy seat
Early Gen 1 two piece rear bumper
2 sets of SWB Gen I rear seat-belts.
Set of Aisin Hubs.
Re: Strengthening KM145 5 speed [Re: NickR] #970657 11/11/09 03:17 AM
MainstreaM Offline
try a place with a water jet. It would be faster for them to cut and in the machine shop world, time=money.
89 Conquest - 2.4 DOHC <--Thats right DOHC Turbo and MPI.
87 Starion flatsider - under restoration
87 Conquest - Saved from the crusher
86 Conquest - Another crusher rescue
88 Conquest - Previous owner abandoned project
87 Raider - under construction
86 Conquest - DD
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6487 MB (Peak: 0.7740 MB) Data Comp: Off Server Time: 2026-05-26 03:49:13 UTC
