Coolant flush #970756 11/05/09 03:51 AM
U
uareahosereh Offline OP
I just finished flushing the radiator on my 96 T100 4x4 and was refilling it with coolant. I does not seem to be taking the required amount of coolant. Its supposedly supposed to take a little while but how long is it supposed to take? Also I was wondering an easy way to drain the reservoir because right now it has water in it from when I flushed out the system. Thanks
Re: Coolant flush [Re: uareahosereh] #970757 11/05/09 04:32 AM
ErikB Offline
Toyota Moderator
Pull the reservoir out and dump it.
After I do a flush it usually won't fill all the way back up. Just fill the reservoir, put the cap on and start driving. After a few driving cycles the radiator will suck in fluid as needed (whenever the cooling system cools). Just check the reservoir periodically and add more as needed.
Also, the factory thermostat has a jiggle valve in it presumably to help bleed air through it, which might help a bit.
http://home.4x4wire.com/erik
Re: Coolant flush [Re: ErikB] #970758 11/05/09 06:10 AM
Adam F Offline
Remember, there is coolant inside the engine block, intake manifold, and your heater core. So unless you flushed and removed all the coolant from these, there will still be quite a bit of coolant still in the system.
Flushing the radiator alone only removes maybe half of the total coolant, and is not good enough if you have dirty fluid.
97 4R, stock, daily driver
Re: Coolant flush [Re: Adam F] #970759 11/05/09 07:11 AM
U
I think I flushed the whole thing, I disconnected the bottom hose and than ran a hose through the top and ran the truck for 5 or 10 minutes. If so I figured out the reason the coolant wasn't filling was because I needed to jack up the front of the car. As for the reservoir is there an easy way to take it out the only way I'm seeing is two bolts that look pretty difficult to get to. Thanks for your help
Re: Coolant flush [Re: uareahosereh] #970760 11/05/09 08:22 AM
BamZipPow Offline
[quoteAs for the reservoir is there an easy way to take it out the only way I'm seeing is two bolts that look pretty difficult to get to. Thanks for your help [/quote]
It just hangs on the bracket...just pull the cap off and then pull the entire reservoir up and out. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Coolant flush [Re: uareahosereh] #970761 11/05/09 09:10 AM
kewlynx Offline
Time for you to download a factory service manual before ya get yerself into trouble. <img src="/forums/images/graemlins/wink.gif" alt="" />
www.techinfo.toyota.com $10 and a 24 hour download window.
**ubi apis- ibi salus**
Re: Coolant flush [Re: uareahosereh] #970762 11/05/09 04:34 PM
ErikB Offline
Toyota Moderator
That typically doesn't do the best job because the cool water you flush it with doesn't let the thermostat open and flush out whats in the engine block.
Removing the thermostat as well as the drain plug in the engine block just in front of the passenger's side motor mount will drain the most fluid and then you can do a much more thorough flush. Adding a fitting to the heater hose to attach a garden hose helps flush fluid out from that end of the system too. Prestone sells a kit for that.
Re: Coolant flush [Re: kewlynx] #970763 11/05/09 04:49 PM
BamZipPow Offline
Actually...they raised the price last time you were there. It now starts out at $15 fer a 2 day window... <img src="/forums/images/graemlins/wink.gif" alt="" />
Code
Subscription Term
  	Standard  	Professional Diagnostic 	Security Professional*
2 Day 	$15 US 	$55 US 	$55 US
Monthly 	$75 US 	NA 	NA
Yearly 	$400 US 	$995 US 	$995 US
Re: Coolant flush [Re: uareahosereh] #970764 11/05/09 07:45 PM
Adam F Offline
I see. But that still leaves hose water trapped in the system (block, heater core, intake)
So unless you've disconnected the heater core, blew it out with an air hose, and unscrewed the block drain plug, then all that hose water is still in the engine. THAT'S why you aren't able to fit the specified amount of coolant (which is from a dry fill)
Re: Coolant flush [Re: Adam F] #970765 11/05/09 08:11 PM
jmoser Offline
I never put any water in the system for flush or fill unless it is distilled. Tap water from your garden hose can have all sorts of undesireable minerals, chlorine, sediment, etc. depending on your local water supply.
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6446 MB (Peak: 0.7663 MB) Data Comp: Off Server Time: 2026-05-29 14:57:13 UTC
