run-out on front brake rotors #970896 11/06/09 06:06 AM
hutchakai Offline OP
Hi, I've got a '94 Toyota Pickup DLX 4x4 that has developed a shimmy in the brakes after having to slam on them in traffic. I want to pull the front rotors and either have them turned or replaced, and was reading in the service manual about measuring the disc run-out before pulling them, and after installing. I've never heard of this before, can anyone explain what "run-out" refers to, and how to measure it?
Thanks!
Re: run-out on front brake rotors [Re: hutchakai] #970897 11/06/09 07:12 AM
kewlynx Offline
Around page 5- we have a '93 FSM in the sticky for this section BTW.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/brakesystem/8-4wds1212.pdf
Here is a very good description of runout and how to check it:
How to check runout
**ubi apis- ibi salus**
Re: run-out on front brake rotors [Re: kewlynx] #970898 11/06/09 11:45 PM
CJMT100 Offline
FYI the job of changing rotors on these trucks is a PAIN. The hub itself is pressed into the rotor.
Re: run-out on front brake rotors [Re: CJMT100] #970899 11/09/09 02:17 AM
kewlynx Offline
Yep, not like the older Toys.
Re: run-out on front brake rotors [Re: kewlynx] #970900 11/09/09 05:18 AM
Adam F Offline
Just hammer a pickle fork in between the rotor and the hub.
97 4R, stock, daily driver
Re: run-out on front brake rotors [Re: CJMT100] #970901 11/10/09 03:41 AM
OOP'S Offline
I have never had a problem getting rotor off of hubs, IFS or SA. They are not pressed on, rusted maybe but not pressed. I just took two IFS rotors off yesterday that were very rusted. The bolts spun right out and a couple of hits with a 3 pound dead blow hammer and they fell off.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: run-out on front brake rotors [Re: OOP'S] #970902 11/10/09 10:59 PM
CJMT100 Offline
Well by pressed I mean they are basically friction fit. I tried to do mine once and spent a good 2 hours and finally got out the torch-wouldnt come loose easy.
A friends we said F it and cut the rotors off, wouldnt come off. Another friend I had access to a press and that worked. Remember you live in CA, no real rust there.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6198 MB (Peak: 0.6939 MB) Data Comp: Off Server Time: 2026-06-07 06:30:05 UTC
