Weird sound coming from my Runner. #91094 09/11/02 11:48 PM
Bighead Offline OP
Here is my problem:
I am getting an unusual clanking sound from underneath the front end of my 4Runner when I initially engage my brakes. It sounds like 2 pieces of metal clanking together. It is really noticeable when I am braking at a speed of 35 mph or slower. When I am at higher speeds it either doesn't do it or I can't hear it.
I haven't taken any damage to my undercarriage. There was nothing out of the ordinary in my visual inspection. I have had friends listen while I replicated the noise but nobody has any idea what it could be.
Let me know if there is any more information I can add that may be of help in figuring this out.
Lance
2001 Toyota 4Runner 4WD Limited | 4.88s/Dual ARBs | OME/Tundra Suspension | Aisin Manual Hubs | BFG A/T 285/75 | TJM T-15 w/ M8000 | Nuke Discos | Slee Sliders | Rockware Rear Bumper/Tire Carrier
Re: Weird sound coming from my Runner. #91095 09/12/02 12:42 AM
i had some similar noises in the front of mine,
i greased up the front end & sprayed wd-40 all around & the noise went away,
not sure what the noise was ?
good luck !!!
Re: Weird sound coming from my Runner. #91096 09/12/02 02:42 AM
i have a similar noise, but only when I back up and hit the brakes. The toyota stealer says it's the brakes adjusting. I don't think so. Doesn't seem to bother anything else.
Sounds like sticky calipers or pads to me. A definite "clink" sound, though.
Mike
Re: Weird sound coming from my Runner. #91097 09/12/02 03:30 AM
Check your anti-sway bar bushings.....possible that one or both are blown.
Re: Weird sound coming from my Runner. #91098 09/12/02 04:48 PM
I lurk around here on occasion soaking up the knowledge that is abundant so I don't usually post much.
However this problem sounds alot like the the problem I had with my 2000 runner. I had it in to one dealer and they couldn't figure it out so they waid it was normal. I drove around like that for months and it drove me nuts. So I decided to try another dealer and they fixed it under warranty. They replaced the "front pads and shim kit". Problem solved.
I hope yours is as easy.
Gunter
Re: Weird sound coming from my Runner. #91099 09/13/02 05:38 AM
I think this should help.
http://club.vmag.com/ubb/Forum2/HTML/000810.html <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
Re: Weird sound coming from my Runner. #91100 09/12/02 10:50 PM
Bighead Offline OP
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by Tokmak:
<strong>I think this should help.
http://club.vmag.com/ubb/Forum2/HTML/000810.html <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Thanks, but wrong sound. I know that one. This is a clanking that really (don't want to say definately) sounds metal on metal. My first instinct said "brakes" but I am not smart enough on them to make that determination.
Lance
Re: Weird sound coming from my Runner. #91101 09/12/02 11:05 PM
Bighead,
The sound mine was making seems alot like you describe. You should try to get it fixed under warranty like I did. If you don;t want to fix under warranty or the dealer balks at replacing a normal wear item (brakes) you could replace the pads and shim kit yourself. It seems like a pretty cheap fix.
Gunter
<small>[ September 12, 2002, 06:07 PM: Message edited by: retnug ]</small>
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.007s) Memory: 0.6090 MB (Peak: 0.6901 MB) Data Comp: Off Server Time: 2026-11-18 03:28:46 UTC
