Can't locate a new Electric Choke (MotorCraft) - Carter 2BBL #971055 11/07/09 08:37 PM
LittleMuleCJ7 Offline OP
Good Afternoon Jeepers,
The 82 started running rough then wouldnt start. On further inspection, one of the screws that holds the electronic connection to the electric choke had backed out and the center spring is gone. I've searched Quadratech and Morris 4x4 as well as some other sites online; no luck. All the sites want to sell a new carb only with the electric choke. Does anyone know of a good resource for just an electric choke? Thanks a bunch!
OIIIIIIIO
82' CJ-7, SOA and many other goodies.
Re: Can't locate a new Electric Choke (MotorCraft) - Carter 2BBL [Re: LittleMuleCJ7] #971056 11/08/09 02:54 PM
For those who may be interested; Found it. $29
http://www.carburetion.com/_inv/invtocartpic.asp?Part1=EC-63C3F
OIIIIIIIO
Re: Can't locate a new Electric Choke (MotorCraft) - Carter 2BBL [Re: LittleMuleCJ7] #971057 11/10/09 09:03 AM
BobRowe Offline
Thanks for posting the info.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5923 MB (Peak: 0.6452 MB) Data Comp: Off Server Time: 2026-06-21 20:21:20 UTC
