Broken rear diff toyota tacoma #971177 11/08/09 10:42 PM
MartinB Offline OP
Do a 1996 -2001 toyota tacoma rear diff will fit a 2003 tacoma
Re: Broken rear diff toyota tacoma [Re: MartinB] #971178 11/09/09 06:12 AM
Adam F Offline
Yes.
There are 2 diffs.....one with the trd locker, and one without. These 2 diffs are NOT interchangeable.
97 4R, stock, daily driver
Re: Broken rear diff toyota tacoma [Re: Adam F] #971179 11/10/09 06:59 PM
totalloser Offline
The electric locker is basically an 8" like all the older axles, with 30 spline axleshafts, but a 4 pinion carrier and odd 3rd member bolt pattern with a notch to clear the locker actuator.
The non-trd Tacomas have a 8.875" axle in which most the components are bigger, from the housing and ring gear to the third member bolts. I *think* all the 8.875" thirds are interchangeable. The spline count is still 30 spline, and the flange on mine was the same (swapped to a TRD housing, kept my stock axles/brakes-minor fabrication required)
OH, and if you broke your spider gear/side gears, and your ring and pinion are still OK, it is VERY VERY EASY to slip in a "lunchbox" locker like a no slip or a Lockright. I am not a fan of the EZ locker (broke mine on my sami) but there is really no gear setup. Just adjust the backlash to what it was before. The locker will be stronger than the OE stuff. Usually when a Toy diff goes, it's because the drive flange nut was loose, or the spider/sides went. This is why I'm mentioning this. Probably CHEAPER than new parts.
Re: Broken rear diff toyota tacoma [Re: totalloser] #971180 11/13/09 08:49 AM
kewlynx Offline
Good info to know guys. My 2004 Taco has the first selectable TRD elocker on it that I've ever had. Bit strange; am a little scared to try it on ice at the moment- only 4 payments so far! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
**ubi apis- ibi salus**
Re: Broken rear diff toyota tacoma [Re: kewlynx] #971181 11/16/09 07:25 AM
Jeff the marmot Offline
Always use 4x4 and open diffs on ice. Locked diff = guaranteed spin on ice. A locked diff is very beneficial in deep snow, though.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Broken rear diff toyota tacoma [Re: Jeff the marmot] #971182 11/18/09 06:41 AM
kewlynx Offline
Thanks Jeff, been awhile since I've had to think about it. Selecting the elocker sure has a hefty thump when it engages! 4x4 by itself has done well, esp with a camper on the back late Sept in the high country.
I've got 8 acres to give snow a try once it gets deeper! <img src="/forums/images/graemlins/notooth.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6119 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-06-20 17:53:32 UTC
