Page 3 of 5 1 2 3 4 5
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: MontyMcV] #971307 11/10/09 06:06 AM
Scottie2113 Offline
my brother will have to verify the work on the front oil seals, but I believe they were also replaced in this service.
what we are trying to determine is, what is still causing the random misfire code? we know for sure the HB was bad b/c the rubber was separated from the metal disc. even after HB was replaced, still the same random misfire code exists.
so is it from a damaged crank or bearings?? OR is it possible that something else needs to be checked out?
thanks to all who have provided input so far, any additional insight is welcome.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: Scottie2113] #971308 11/10/09 06:43 AM
Kevin C Offline
It is a really really good question, how was it determined that the engien was bad? I was assuming that it was something more than; cause I just guessed!
A good test is to send a sample of the engine oil out to a lab and or pull the oil filter apart to look for a trashed bearing.
If there are no other signs I agree that a bit of a reach, or reach around as the case might be to say the bottom end is bad.
Kevin
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: Scottie2113] #971309 11/10/09 08:12 AM
87Montero Offline
Scott, first of all. Pittsburgh won! <img src="/forums/images/graemlins/smile.gif" alt="" />
Secondly. I had too many shots of crown and Sambvka.
In other news... I stand that a rod knock or worn out bottom end will not cause a misfire code!
Literally, I saw a 6G74 DOHC go out, but it did not throw a CEL when I spun my bearing/s entirely.
Hope for the best man.. if he was close, I'd rip it out and do some work.
Brendan
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: 87Montero] #971310 11/10/09 01:44 PM
Scottie2113 Offline
Who on here is smart with ECU codes?
What triggers the engine to think random misfire?
does engine have ability to recognize build up of improperly combusted gases in combustion chambers?
what sensors or feelers if you will, does the engine use to determine random misfire?
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: Scottie2113] #971311 11/10/09 02:27 PM
haztoys Offline
Sigh ...Thank the Lord I stopped the mechanic life at times like this ..
Sorry on the car ..
The dampner in its self being loose could set the code I'm sure ...
Hang a dampner on it see what it does ... See if a new dampner will even stay tight on the crank end ..
Loose dampner can nock like a rod sound ..By the way ..
David
Hazardous Toys inc
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: haztoys] #971312 11/10/09 02:43 PM
Mad_Scientist Offline
Could the bad HB have damaged the crank position sensor leading to the code? <img src="/forums/images/graemlins/confused.gif" alt="" /> Just guessing.
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: haztoys] #971313 11/10/09 03:03 PM
Scottie2113 Offline
I repeat...........a new balancer was installed and check engine light still comes on.
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: Scottie2113] #971314 11/10/09 03:05 PM
Scottie2113 Offline
and just in case someone missed the last post:
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: Scottie2113] #971315 11/10/09 03:15 PM
Marcus2113 Offline OP
So was a new balancer installed yet?!
On a more serious note, all we know right now is that even with a new balancer installed, after it warms up, there is still a noise in the lower part of the engine and the check engine light still comes on saying there is a random misfire. I am going to call the "tech" this morning to find out more details. I will be posting them up later.
Thanks again for all the imput.
99 Montero, 3.5 L, Auto, Front/Rear Lockers, 2" Body Lift, 35's, 4.90's, Rock Sliders, Front/Rear Recievers
Re: Mitsubishi Dealer takes NO responsibility!!! [Re: Scottie2113] #971316 11/10/09 03:16 PM
Maybe check that that new balancer could be bad? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 4.018s Queries: 16 (4.014s) Memory: 0.6442 MB (Peak: 0.7695 MB) Data Comp: Off Server Time: 2026-10-24 03:16:47 UTC
