Front Diff. Leak Passenger side seal! #971660 11/10/09 10:57 PM
HuntingRig Offline OP
I lost a bolt on my front diff. which caused my CV boot to explode & I figured it was time to change the CV shaft anyways so I have it torn apart.
I have always had a leak on the passenger side of my front diff. but it has never been to bad.
Should I change the seal on that side or is it a pain in the butt?
I have it torn apart & I am ready just to throw the new CV shaft back in but I wanted to clear it with the experts!
Re: Front Diff. Leak Passenger side seal! [Re: HuntingRig] #971661 11/10/09 11:11 PM
I just need a quick opinion, I won't hold anyone to it. I don't have a lot of time right now, so any opinions will be considered...
Re: Front Diff. Leak Passenger side seal! [Re: HuntingRig] #971662 11/10/09 11:44 PM
mgd4me Offline
imo if it apart change it out. if that was mine, and i didn't change it. it would go the next week. i have played that game and lost almost every time.
94 ex cab 3" body...33" bfgs... 1 roll over..stocker
http://www.youtube.com/watch?v=tYlDedAt96Y
Re: Front Diff. Leak Passenger side seal! [Re: mgd4me] #971663 11/11/09 12:25 AM
OOP'S Offline
Pop the stub shaft and replace it, get it from Toyota!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Front Diff. Leak Passenger side seal! [Re: OOP'S] #971664 11/11/09 02:58 AM
kewlynx Offline
x 2 Better to change that than a trashed pumpkin. Check the condition of the carrier bearing while it's open if you can.
**ubi apis- ibi salus**
Re: Front Diff. Leak Passenger side seal! [Re: kewlynx] #971665 11/11/09 05:06 AM
ErikB Offline
Toyota Moderator
Easy to replace. Napa carries the seal too, but I'm sure the Toyota one is better quality.
http://home.4x4wire.com/erik
Re: Front Diff. Leak Passenger side seal! [Re: ErikB] #971666 11/13/09 08:34 PM
How do you get to the darn thing? Do you drop the pumpkin & then take off front cover or do I have to take the driver side shaft off?
Do I need to get a new snap ring?
Oh its an '87 4runner...
I already bolted it up but I know I am just avoiding the inevitable.
Re: Front Diff. Leak Passenger side seal! [Re: HuntingRig] #971667 11/14/09 01:00 AM
OOP'S Offline
It is in here;
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Even though this is an FSM for a 93, the front diff is the same.
David Fritzsche
Roseville, CA
Re: Front Diff. Leak Passenger side seal! [Re: OOP'S] #971668 11/14/09 05:02 AM
I looked at this diagram already:
front seal
So my question is do I have to pull the opposite side shaft out? Do I have to disassemble the entire front gears to get to the snap ring or do I use the SST to pull the passenger side shaft?
I am not trying to be rude, I am just letting you know that I am not the most gifted when it comes to this stuff. With that being said I usually just usually end up costing myself a bunch of money & time.
I also looked at the dissembly diagram & I damn sure don't have time or the patients to get that done without my wife kicking me out. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Front Diff. Leak Passenger side seal! [Re: HuntingRig] #971669 11/16/09 03:51 AM
OOP'S Offline
I am not really sure but I do not think you have to tear it all apart. The stub axle just pops out, you may need to use a slide hammer to pop it out. I broke a stub axle years ago and replaced it while the diff was still in the truck.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6374 MB (Peak: 0.7610 MB) Data Comp: Off Server Time: 2026-06-07 03:20:22 UTC
