ECU relocation #973194 11/21/09 06:36 PM
3
357transam Offline OP
Just wondering if anyone has relocated the PCM to another place that sits higher up. After my recent flooding of the interior, I realized that if i had flooded the right side of the car, bye bye PCM. <img src="/forums/images/graemlins/scared.gif" alt="" /> I dont want to extend the wiring, seeing as how there is probably fifty wires to the PCM, which limits me to only about 1' of movement. Any ideas? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: ECU relocation [Re: 357transam] #973195 11/21/09 07:20 PM
DEFBOY35 Offline
move it up higher towards the glove box.i plan on extending my harness and moving it up as high in the dash as possible.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: ECU relocation [Re: DEFBOY35] #973196 11/21/09 08:29 PM
3
Yeah, i guess i will use the original mounts and just move it up one bolt, support it with something at the top. That gives me about 1 or 2 inches higher. may end up just extending the harness.
Re: ECU relocation [Re: 357transam] #973197 11/21/09 09:35 PM
fokion Offline
extending the harnes may proove risky.
it has about 40 pins or more...
extending it means ( to my mind ) having 2 times 40 possibilitis of something not solderd right or get rusty in due time...
connectios may proove a weak link..
Re: ECU relocation [Re: fokion] #973198 11/21/09 09:36 PM
fokion Offline
I would advise to see if by loosening the harnes may give you "free" cable to moove the ecu highier without an extension
Re: ECU relocation [Re: fokion] #973199 11/21/09 10:47 PM
4
4runnernomore Offline
When I had my Powerchip fitted I placed close attention to this when they were removing the ECU. Once you have unbolted it you actually have a reasonable amount of movement withthe wires leading into it.From memory you should be able to turn the wiring harness around 180 degrees and be able to locate you ECU right up under the dash. Mounting Points to screw into will be the issue.
The ECU is actually quite robust and is able to handle awater dunking. Adskia has dunked his on a couple of occasions and has dried it out and got under way again with minimal consequences (apart from ribbing from his mates form using an exhaust to dry it out). <img src="/forums/images/graemlins/zombie.gif" alt="" />
My suggestion is pull the carpet up, undo the ECU and have a good look at the wiring. There could be a couple of bolts/clips that may hod the wiring harness in postion. Once these are undone you should have the movemement you are looking for.
Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: ECU relocation [Re: 4runnernomore] #973200 11/22/09 02:37 AM
DamKia Offline
Kia Moderator
x2 on that.
I've dunked mine 3 times, water to the top of the gearstick. Dried over a mates demister.
Re: ECU relocation [Re: DamKia] #973201 11/22/09 04:26 AM
KIAFREEKROB Offline
Why not keep it in the same place & find a plastic water tight container to fit it in. Cut holes to run the mounting bolts & wiring, then reseal the holes with silicone.
Why go around? When You can go over!
Re: ECU relocation [Re: KIAFREEKROB] #973202 11/22/09 09:32 AM
DamKia Offline
Kia Moderator
Needs a good electrical contact to earth, also needs good airflow/metal to metal contact for cooling of the ignition and fuel injection transistors.
Re: ECU relocation [Re: DamKia] #973203 11/22/09 11:43 PM
3
All good points from everyone. There is some movement, but not a lot. I like the idea of moving it behind the console somewhere. But then again, if they don't seem to have any major problems with water, maybe i won't really worry about it. I TRY to stay away from deep stuff anyways....
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6411 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-10-24 08:20:33 UTC
