Cherokee security system problem
#973242
11/21/09 11:28 PM
My son disconnected the battery on his '97 Cherokee to do some work. When he re-connected it, all the lights (inside and out) started flashing and and the ignition was disabled. We can't find any aftermarket alarm system. Is there a way to reset a factory security system without a remote?
Back in the game! '94 YJ 2.5 all stock.
Re: Cherokee security system problem
[Re: fresnodb]
#973243
11/22/09 12:29 AM
Problem solved, found the aftermarket system valet switch!!! Turned the ignition on, pushed the switch three times and that was it.
[Re: fresnodb]
#973244
11/26/09 04:21 PM
Alot of times, if you turn the ignition key to the run position, THEN connect the battery, the aftermarket alarm will be turned off, allowing normal starting.
[Re: MartySoCal]
#973245
11/28/09 12:52 AM
Thanks, probably the one thing I didn't try! I'll remember that one.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6003 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-05-29 23:58:39 UTCValid HTML 5 and Valid CSS
