Cherokee security system problem #973242 11/21/09 11:28 PM
fresnodb Offline OP
My son disconnected the battery on his '97 Cherokee to do some work. When he re-connected it, all the lights (inside and out) started flashing and and the ignition was disabled. We can't find any aftermarket alarm system. Is there a way to reset a factory security system without a remote?
Back in the game!
'94 YJ 2.5 all stock.
Re: Cherokee security system problem [Re: fresnodb] #973243 11/22/09 12:29 AM
fresnodb Offline OP
Problem solved, found the aftermarket system valet switch!!!
Turned the ignition on, pushed the switch three times and that was it.
Back in the game!
Re: Cherokee security system problem [Re: fresnodb] #973244 11/26/09 04:21 PM
MartySoCal Offline
Alot of times, if you turn the ignition key to the run position, THEN connect the battery, the aftermarket alarm will be turned off, allowing normal starting.
Re: Cherokee security system problem [Re: MartySoCal] #973245 11/28/09 12:52 AM
fresnodb Offline OP
Thanks, probably the one thing I didn't try! I'll remember that one.
Back in the game!
PHP: 7.4.33 Page Time: 0.512s Queries: 15 (0.386s) Memory: 0.6009 MB (Peak: 0.6559 MB) Data Comp: Off Server Time: 2026-10-21 16:19:19 UTC
