Can't Find Source of a Transmission Fluid Leak #973321 11/22/09 06:41 PM
Hermit Offline OP
Hi, new here. Just picked up a 1993 Trooper LS and noticed recently that I was seeing a trans fluid spot on driveway. I have seen drops on the skid plate at the trans mount bracket but can't find the source of the leak. I have tightened the bolts on the pans since those gaskets were just done.
Any suggestions on what it could be from and is this an easy fix or something I need to go to a trans shop to have handle.
Thanks <img src="/forums/images/graemlins/confused.gif" alt="" />
1993 Trooper LS Basically Stock 3/2 DOHC well over 255,000 on original engine and trans
Re: Can't Find Source of a Transmission Fluid Leak [Re: Hermit] #973322 11/23/09 04:46 PM
lttlbddy Offline
Pull the skid plate so that you can see where the leak is coming from.
Re: Can't Find Source of a Transmission Fluid Leak [Re: lttlbddy] #973323 11/26/09 03:13 AM
barak Offline
Is it the 4L30? if so , look for a round metal plug on the side , about 2" in diameter.there is a seal in there , and if that seal is gone it will leak , I had mine go on me and it took my mechanic 2 minutes to change the seal as they knew what it was when I was stumped.
Re: Can't Find Source of a Transmission Fluid Leak [Re: barak] #973324 11/29/09 04:34 AM
Hermit Offline OP
Thanks. Took it too a Transmission shop and after replacing the two top plug seals and the shift shaft seal it looks like the problem is finally fixed.
93 Trooper LS Auto 255,000 @ 11/28/09
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6025 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-05-29 17:25:30 UTC
